gears, need help
  • Thread starter Thread starter 89five0
  • Start date Start date Feb 20, 2004
89five0
50
  • Feb 20, 2004
well my car is an 89 gt with about 125,000 miles on it an still running strong. so far this is what mods are done to it: bbk shorty headers, matching h-pipe w/cats,american thunder flows, msd distributor,and plug wires, also bbk CAI fenderwell. i was wondering if 373 gears would be a good upgrade for my car and still making it streetable? Also i am thinking of getting some U/D pulleys what do you reccomend? With these mods should i be able to reach the 13s? also any other easy mods do you suggest. thanks
5.0 HOtrain
2,247
New Hampshire
Feb 20, 2004
  • Feb 20, 2004
Is it a vert or regular gt? 5spd or auto? If 5spd go with the 3:73's, 4:10's if an auto. Streetability you're worried about?? The thing will be a blast from what it is now. With a 5spd, 303rwhp and 3:73's in my car, I still got 24-26mpg on the highway and 17-20 around town. You'll love them, go for it
Mike.
willys1
1,004
New Jersey
Feb 20, 2004
  • Feb 20, 2004
If you ever cruise at 80--90mph,,you might not like 373's..I agree for more performance go 373's,,if you do alot of highway driving you might wanna think 3..55's.JMO!!
89five0
50
  • Feb 20, 2004
thanks
it is a hatch and also a 5spd. i wont do alot of highway driving so it wont really matter. also how much of an offline line difference will i feel. do you think i will reach high 13s. also where do you reccomend to buy the gears and what all is needed for it to get done? also what about th u/d pulleys?
5.0 HOtrain
2,247
New Hampshire
Feb 20, 2004
  • Feb 20, 2004
Go with the 3:73's and dont worry about highway. I believe my car was around 2600@75 or so, somewhere in the ballpark of that. Do the gears and hang on. Do the rebuild kit when do it.
mike.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 20, 2004
  • Feb 20, 2004
Do a 87-88 Thunderbird Turbo Coupe rear end swap and get either 3.55's or 3.73's and disk brakes as a bounus...
It takes 2 guys the first day to get the old rear end out and the new one bolted in place. It takes 1 guy another whole day to do the brakes.
Auto trans Turbo Coupes come with 3.73 gears and manual Turbo Coupes come with 3.55 gears. I choose 3.55 since I do more highway driving.
You will need a several sets of fittings, I recommend that you get them from Matt90GT's website, http://www.svo73mm.cjb.net/. Read Matt's instructions thoroughly, everything you need to know about the brakes is all there. You need to be patient and follow all the internal links, and there are many of them. You will need 2 fittings in the rear to adapt your old brake tubing to the TC disk brakes. The fittings go between the steel tube and the caliper brake hose. You will need another set of fittings to make a 2 port to 3 port adapter. To make life simpler, just buy the kits from Matt. You could piece them together, but it's not worth the time unless you work at an auto parts store with all the fittings ever made. You will need to drill the quad shock mounting holes 2” below the holes drilled for the Turbo Coupe mounting points. The bolts are metric, so don’t loose them or the nuts. A 15/32” drill should be about the right size unless you have access to metric sized drill bits. Going without quad shocks is not an option unless you have aftermarket parts to soak up the wheel hop.
You will need a proportioning valve, Summit has one for $40 + shipping.
You will need a kit (FMS makes the part) to gut the stock proportioning valve, Summit also has that, about $10.
You will need a new master cylinder, see Matt's site and make you choice. I used a 94-95 Mustang master cylinder. Note that rebuilt 94-95 Mustang master cylinders do not come with a reservoir. That means a trip to the junkyard and some more money spent.
Your brake pedal may be very hard and almost impossible to lock up the brakes. I had to replace the front calipers with 73 mm calipers from a 91 Lincoln Mark 8 to get the braking performance up to par.
See http://www.mustangcentral.net/tech/brake.html for help with the emergency brake. The ebrake handle on 87 and later models must be modified by removing the spring, and tack welding the pawl and ratchet assembly.
Bleeding the brakes will require 2 people and some coordinated effort. I don’t recommend using you wife or girlfriend to pump the pedal – they get offended when you yell at them. I used a homemade power brake bleeder constructed from a garden sprayer and some fittings from Home Depot. It cost about $25 and was worth every penny.
All in all I have been very pleased with the results.
donkey_punch
565
northern****ingjersey
Feb 20, 2004
  • Feb 20, 2004
i have 3:73 and love it. but make sure you buy an alumin. drive shaft also. so you won't have to deal with vibration in your drive train.
no offence to jrichker, but for all that you mention above. he might as well rebuild what he has with a new posi, and new 31 spline axels. and for rear disc brake conversion. check this place out. http://www.p-s-t.com/ford/fodbconv4.html
willys1
1,004
New Jersey
Feb 20, 2004
  • Feb 20, 2004
If you dont care about highway,,go 410's.Gears cost 189.00,,get Ford Motor Sport gears there the quietest,,and labor is around 200 Beans!,,But jrichker seems to know his sh@t!!! Having disc brakes in the rear is a bonus
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Feb 20, 2004
  • Feb 20, 2004
Yes those mods should get you 13's...by the way go 373's...
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
