  • 1994 - 1995 Specific Tech
Gears problem
  • Thread starter Thread starter click
  • Start date Start date Sep 11, 2004
C
click
142
  • Sep 11, 2004
Im not sure what the problem is but, when i start off in first i press the gas let of the clutch slowly. my foot could be completly off the clutch and the car will still be reving. When i put it in 2nd and then i mash the gas the car revs first then the car goes.
HISSIN50
34
129
Sep 11, 2004
  • Sep 11, 2004
slipping clutch. check clutch adjustment if you can, and otherwise...........
good luck.
C
click
142
  • Sep 11, 2004
and otherwise... new clutch?
donjohn
1,757
Irvine - Southern California
Sep 11, 2004
  • Sep 11, 2004
yes
HISSIN50
34
129
Sep 11, 2004
  • Sep 11, 2004
yeah, thanks DonJohn.
the thing is slipping for a reason. either the cable is all out of adjustment (someone put a ton of preload on it. if you get under and can tug the cable at the bellhousing and there is slack, preload is likely not an issue).
the disk could be saturated in fluid or the pressure plate fingers let go. there are other reasons, but those are some of the biggies.
did this come on all of a sudden?
C
click
142
  • Sep 11, 2004
Ya it was fine. Then at one stop sign it happened.
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
