  • SN95 4.6L Mustang Tech
GEARS
  • Thread starter Thread starter 2003_GT
  • Start date Start date Nov 5, 2008
First Prev 2 of 2
04YELLOWGT
1,135
Indiana
Nov 8, 2008
#21
  • Nov 8, 2008
  • #21
GTRACER88 said:
It all depends on the application. You dont want more than 3.73 on an auto. What will happen, also depending to your tire size, is that anything above 3.73 you will run out of gear at the track. What will happen is that you will enter overdrive and that is really risky because you can brake the band if you enter it at wot. For instance, i have 315/30/18 in the rear and if i had 3:73, that would mean i would be at the end of 3rd gear at 118.1 MPH. if i had 3:90 i would be at 113.0 MPH. I run nitrous and i trap speeds of 108-115. I would need something that keeps me in that range which would be 3:73. It all depends on your set up and what you want to have.
How do you trap between 108 and 115? Thats a pretty wide range I'm usually with in a few mph.
Uhh I have an auto and with 274/45/17s and 4.10s I went 120+ in 3rd with O/D locked out. I now have a built auto and though I know its still not great on the tranny I **** into OD at the track and trap 128.
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Nov 8, 2008
#22
  • Nov 8, 2008
  • #22
I was gonna say that seems like a pretty wide mph range. I always heared(i don't have an auto so i don't know) that with an auto you would WANT to go at least 4.10's. I havent gone to the track very much lately(due to getting the trans and rear built) but my times were always within a few mph as well
G
GTRACER88
#23
  • Nov 8, 2008
  • #23
Well, i run nitrous which is not very consistant, it depends to on the set of wheels i use. When i use the 18's im, like you said within a 3 mph range. When im on the v6 rims with Mickey Thompson i get better times. Also when i run N/A i dont trap as high. Also sometimes my tires arent warmed up and i spin causing me to have a higher MPH. Some times i run out of gear and i let go so i dont enter WOT with the nitrous on, right at the end of the strip.
fast97gt
1,082
north carolina
Nov 9, 2008
#24
  • Nov 9, 2008
  • #24
4.10s with an automatic...wow hope you like buying gas!!!
04YELLOWGT
1,135
Indiana
Nov 9, 2008
#25
  • Nov 9, 2008
  • #25
The car runs though.
Before I did the blower and all the other goodies I got around 16-18mpg and that was 90% city drving.
02nightmaregt
Jul 1, 2007
513
Southern Indiana
Nov 9, 2008
#26
  • Nov 9, 2008
  • #26
Thats not too bad actually. Esp. for an auto.
fast97gt
1,082
north carolina
Nov 9, 2008
#27
  • Nov 9, 2008
  • #27
what about the highway? i get (actually my wife) 20-22mpg in the city and and 19-20mpg on the hwy at like 75mph and 2400rpm and thats a 5spd. however its not that much lower when i drive it.
04YELLOWGT
1,135
Indiana
Nov 9, 2008
#28
  • Nov 9, 2008
  • #28
It was really about the same. The only time I really ever hit the highway was/is when Im heading to the track.
bluelightning
15
orlando
Nov 10, 2008
#29
  • Nov 10, 2008
  • #29
2003_GT said:
I am thinking about buying Motive 3.90 gears for my 2003 mustang GT auto, has anybody had any experience with these gears, if so are they anygood??? any other suggestions on what type of gears are good
would get the Ford racing gears,I have a lot of work done By Lamotta performance in Longwood FL.,when it comes to gears they they won't install anything else.Have had the Ford racing gears in two different mustangs ,no noise, no problems
2003_GT
69
Santa Fe, NM
Nov 10, 2008
#30
  • Nov 10, 2008
  • #30
Thanks ill deffenetly look into the FRPP gears, not too sure wether to stay with 3.73 or do 4.10's but it looks like it all depends on ones own personal prefference by what iv been reading and by the replys iv gotten
BTW car has 60k miles so should i get any kind of rebuild kit???
the98stang
2,408
Clovis, CA
Nov 11, 2008
#31
  • Nov 11, 2008
  • #31
4.10's would be perfect for your auto....especially if you don't do highway driving!
BTW- rebuild kit for sure!
2003_GT
69
Santa Fe, NM
Nov 11, 2008
#32
  • Nov 11, 2008
  • #32
T-LOK rebuild kit or master bearing rebuild kit???
02nightmaregt
Jul 1, 2007
513
Southern Indiana
Nov 11, 2008
#33
  • Nov 11, 2008
  • #33
Master bearing rebuild kit. You could do both but the labor would be more
First Prev 2 of 2
J
High idle 2003 Mach 1
  • JohnnyUtah
  • Mar 29, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
JohnnyUtah
J
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Stuck
  • bshipley
  • Aug 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2026
squeak93
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
