gets fire, no start
blktrunk
Hello,
This is my first time posting, but I have been reading posts here for some time. In fact with the information that I have gained from this site I have turned off air bag lights, turned off check engine lights, and even corrected no start issues in the past on my car.
This time though, I am stumped. My car has fire (it will try to run on starting fluid) but I will not start without. When I turn the key the fuel pump does not prime and the car just spins over. I can tap the fuel pump relay and the pump sticks on and I can depress the schrader valve and get fuel out of the rail. I have tried starting in this situation with the pump stuck on, and still no start. The injectors are not firing as confirmed by a noid light that I bought the other day.
What can cause my injectors to not fire?
1993 LX 5.0 coupe five speed, all stock with MSD distributor.
Please help me get my car started!!!
In 07 I changed the computer, (paid an arm and a leg to have the dealership change parts until they diagnosed it) and it ran fine until now. I parked the car in August in my garage and havent had time to drive it. About two weeks ago I tried to start it and it wouldn't. This time I am trying to fix it myself, but I hate to buy another computer just for diagnosis. The battery was dead when I tried to start it this time and I tried to jump the car. Is there anything else that could go bad just from the car sitting?
Your looking too hard into this very simple issue! You need to buy or borrow a pressure tester that hooks to the schrader valve and see if the fuel pressure is in spec or not. Just because fuel comes out does not make it enough to make the car run or fire for that matter. Without something to check the fuel pressure, your wasting your time and MONEY. Check your pressure. Also, if there is not enough fuel the injectors wont fire because the ECM tell the injectors when to fire. You need a new fuel pump.
Just wanted to let everyone know that the problem on my car was the computer. Borrowed one from a buddy and the car fired right up!!!
I always hate when these threads go without being closed with a fix.
I agree im learn a lot here also .its only nuts and bolts.ive been a mechanic all my life.things changed so quick.get yourself an oem book not anything else.my specialty is viberations .im older now and tired and im now interrested in how to get it to run.its a computer world now as you just found
Yea, I am concerned about the fact that I am blowing computers. I did try to jump the car off because off a dead battery when I initially found out the car would not start and I wonder if that had something to do with it. I saw a little arc when I hooked up the ground. (I always hook the ground up last).
Anyone have any ideas as to why I would be blowing computers?
