  • 1994 - 1995 Specific Tech
Getting Gears...what else?
  • Thread starter Thread starter DFG 5OH
  • Start date Start date May 15, 2005
1 of 2 Next Last
DFG 5OH
1,341
Louisville, KY
May 15, 2005
  • May 15, 2005
Well i'll be doing a gear install myself within the next few weeks. I'm getting 3:73's (used). What else will i need for the install? I'm going to rebuild my Trac-Loc so i know i'll need that kit, should i do anything else while i'm in there? Also, wheres a good write-up on how to install, and tricks/tips to do a good job? Theres no doubt that me and my father can do it, just might take a little while
Thanks,
Matt
super302
I'd do anything for free Bapples
May 29, 2004
2,878
Davenport, IA
May 15, 2005
  • May 15, 2005
....get a brain
j/k....good luck on the gear install
DFG 5OH
1,341
Louisville, KY
May 15, 2005
  • May 15, 2005
Fu.
94gts
873
Carmel, New York
May 15, 2005
  • May 15, 2005
do you have a press of somekind. preferably hydraulic???
RIO5.0
6,892
N.H.
May 15, 2005
  • May 15, 2005
I post the link on Corral for info....I did mine with that and a copy of 5.0 mag as they have write-ups to..
I would line up a truck repair shop or the like to pull/replace the bearing if you don't have access to a press....
Be prepared for the rear ABS sensors...your either gonna get em or break em, its a 50/50 on them..
Dont forget to match-mark the DS to the yoke when you remove...just for what its worth..
Save 2 of your best clutches and do the 4 clutch pack set-up...its a tad beefier...
Use a radiator clamp to squish the S spring some for installation...get it 1/2 way in, cut the clamp and finish setting it....will save you a TON of grief getting the mother in...otherwise you can fight it bigtime...
http://www.corral.net/tech/drivetrain/gears.html
DFG 5OH
1,341
Louisville, KY
May 15, 2005
  • May 15, 2005
so how hard is it?
RIO5.0
6,892
N.H.
May 15, 2005
  • May 15, 2005
matthiasj said:
so how hard is it?
I didn't find it all that bad...take your time and you'll be all set...its fairly straight forward...
DFG 5OH
1,341
Louisville, KY
May 15, 2005
  • May 15, 2005
thats what a figured rio, thanks a lot.
67Mustang5.0
58
Colorado
May 15, 2005
  • May 15, 2005
You might want replace all your bearings while you have it apart too. You can get a complete bearing kit for about $100 from Summit.
94-302-vert
1,947
NE CT
May 15, 2005
#10
  • May 15, 2005
  • #10
GET NEW BEARINGS...
I didn;t and mine goes back in the shop wed for me to pay an extra few $$ to ahve them all replaced...
Chris
Henceforward
The Avatar Master
485
#11
  • May 15, 2005
  • #11
All this stuff sounds expensive. I totaled up what it will cost, and it is a lot.
$190 3.73 FMS New from summitracing.com
$100 Bearing Kit
$50 Trac-Loc Kit
$11 speedo gear
$320 Install Price at a performance shop...
Plus shipping...
350 for parts, plus the install...
$670.00 That's a grip.
Is this what a gear swap costs...
(I know it can be lower, $320 is the highest I was quoted, for gears only, not the Trac, Bearings, or Speedo)
DFG 5OH
1,341
Louisville, KY
May 15, 2005
#12
  • May 15, 2005
  • #12
Well you can get the rebuild kits cheaper on ebay, used gears...i'll be doing it cheap, and i'll be doing it myself so NO labor costs.
311green94
22
#13
  • May 16, 2005
  • #13
I have been loking at this also, but thought that it involved alot more like indexing and use of shims. Is that involved or could it be skipped and not have any problems. I have all the parts for the install, including the rebuild kit, but never tried in fear that I wouldn't get the shims right.
stprorolla49
1,455
15
39
Fairfield, CT/North Jersey
May 16, 2005
#14
  • May 16, 2005
  • #14
rio how long did it take you to do the whole job start to finish doing only the gears and new bearings??
DFG 5OH
1,341
Louisville, KY
May 21, 2005
#15
  • May 21, 2005
  • #15
Ok guys, I found a local mustang guy who said he'd do it for $150. He's installed them before, and garenteed NO WHINE. He's also going to sell me used 3:73's for $75, and he said would go in fine, and havent been worn. So heres the list of stuff:
Install - $150
Gears - $75
Install Kit (bearing and all) - $80.00
Trac Loc Rebuild - $50
Thats $355 not including gear oil, and friction modifier. What gear oil should i get, and is there anything else i need to give this guy? I need to provide him with all the parts. Is this it?
DFG 5OH
1,341
Louisville, KY
May 21, 2005
#16
  • May 21, 2005
  • #16
what about a Speedcal and a new speedo gear?
Jester73440
45
#17
  • May 21, 2005
  • #17
gear
I can get you the install kit and the gear brand new motive gear performace for $190 shipped. No difference in performance between ford and motive gear
RIO5.0
6,892
N.H.
May 21, 2005
#18
  • May 21, 2005
  • #18
Does the full bearing kit come with axle and pinion seals??? If not then they should be on your list...all 3 are cheap money and should be swapped while its open...
I just use Ford lube in mine...
With 373s I'm running the White 21 tooth...It doesn't appear to be all that far off...I had the White with my 355s and left it in with these...Someday I'll score a Speedcal in the classifieds and swap it in..
stprorolla49...I didn't swap bearings...mine had 52k and all was fine so I re-used them...prolly took me an a/noon the first time to do em...I got hung up with having to go get the pinion swapped....
DFG 5OH
1,341
Louisville, KY
May 22, 2005
#19
  • May 22, 2005
  • #19
mine will probably need new bearings, and i'm pretty sure that kit comes with everything. I might not worry about a speedo gear right now, i heard 23 tooth was good with 3:73's. How hard are they to change, i might just wait and do that after.
RIO5.0
6,892
N.H.
May 22, 2005
#20
  • May 22, 2005
  • #20
Unplug the connector on the tranny...remove the bolt...pull the VSS...undo a Circ-clip and remove the old gear...10 minute job...
1 of 2 Next Last
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
