Getting pretty ticked off!!!
  • Thread starter Thread starter 87Mustang351
  • Start date Start date Jun 8, 2006
87Mustang351
220
Canada, Nova scotia, Cape Breton
Jun 8, 2006
  • Jun 8, 2006
ok well some of u might know i had a previous thread that my car is shaking at like 120 KPH its more of a viberation now than anything....
these are parts that i have elimanted....2 new universals in my driveshaft which helped,4 new tires ballanced and installed didnt do much at all...new polly urathane tranny mount which helped very little...i have a inner tie rod end gone on my drivers side im gettin replaced monday with a line up...
please help me its been 2 weeks of frigging with this damn this its getting old REAL fast
87Mustang351
220
Jun 8, 2006
  • Jun 8, 2006
BUMP...HELP@ please
KENS89LX
302
Cross lanes Wv
Jun 8, 2006
  • Jun 8, 2006
1. bent wheel
2. bent driveshaft
3. exhaust hitting body
4. could be something in the rear..gears, trac-lok if equipped
87Mustang351
220
Jun 8, 2006
  • Jun 8, 2006
well my exhast is loose now that i think of it...anbd i have 4:10s in the back and a few teeth are chiped off not on the main gears but the spider one i beleive i didnt think that would hurt it becuase it didnt when i brought it home...
D
Daggar
3,902
  • Jun 8, 2006
Is this the car that ran for an unknown number of miles with no tranny cross member at all?
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jun 8, 2006
  • Jun 8, 2006
It looks like you swapped your crossmember on there (based on the thread) If it's still shaking, maybe the driveshaft is bent from driving the car without the crossmemeber?
It's pretty easy to tell if the shaft is bent. Unbolt the shaft from the rear end and then remove it from the trans. Once it's free, use a 4' level and see if there are any gaps between the straight edge and surface of the shaft. You can also roll it across a flat surface to check. If the shaft is true... then just go do some donuts and see if that helps?
87Mustang351
220
Jun 8, 2006
  • Jun 8, 2006
i never ever drove it without crossmember always has been one in and it didnt shake..i have tryed other drive shafts as well same thing...umm i was thinking maybe the mtoor maybe out of a alinement if thats possiable?...and then i might oput my old cross meber back in and try if not im stumped
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
The Death of a Cobra II
  • 76_Cobraii_mustang
  • Oct 2, 2023
3K
1974 - 1978 Mustang II Talk & Tech Oct 3, 2023
2Blue2
