Getting rid of PVC
Roland is right on. Best of both worlds IMHO(breathers are messy). A simple separator works well.
Good luck.
bobbys9350 said:
so i can just plug the hose on the intake and run the catch can from where? thanks!
What are you trying to do? :shrug:
If you plug the pcv hose, how do you plan on venting the crankcase?
Please provide more details on what you plan to do.
I have had been through some major issues, and have finally sorted things out.
I may be able to help, but I need alot of detail on what you have.
In the link I provided there is a "diagnostic" type section. (I don't remember what I actually called the section though) This will help you determine where the oil is coming from.
jason
for most of the time i have no pcv system and two breathers (one on each valve cover). i have the breathers on because i run a sc and while under boost the blowby has no where to go cause the pcv cant vent the crankcase under boost. for smog i have to hook up the pcv again and when it is hooked up, i have an oil separator inbetween the intake and the pcv
Just a thought, but have you tried using multiple pcv valves?
I was having a problem with filling my separator too quickly, but since adding a second pcv I have not accumulated any significant amount of oil in the separator.
jason
Because I am using a box style upper intake it was fairly easy for me to do. I simply used a valve cover on the driver side that allowed mounting of a breather/pcv cap. If you have a stock style long runner intake, this will provide clearance issues to mounting a second pcv on the drivers side. Mounting a second pcv on the passenger side may prevent adequate ventilation of the crankcase as fresh air from the TB/VC hose would want to rush out the pcv mounted on the passenger valve cover.
I think I explained it better in the link I provided above though.
I have not been able to think of an easy way to mount a second pcv when using a long runner intake. If you come up with something please let myself and everyone else here know. I think this is the permanent long term fix for everyones pcv woes.
I have taken several pics, but have not had a chance to post them yet.
I blew the HG in the 408w, and I have to get the 2.3 to pass emissions on Monday. :rlaugh:
jason
