gm 1 wire
  • Thread starter Thread starter 5.0_sleeper
  • Start date Start date Oct 16, 2007
5.0_sleeper
47
  • Oct 16, 2007
Hello, have a quick question for you guys. Was thinking about upgrading to a efan , but have been told stock alt won't hold up much. Instead of a 3g install, was wondering if anybody has tried a gm 1wire alt on a computer controlled 5.0?
If someone has send me some instructions on how you did the wiring.
thanks
aaros
114
Oct 16, 2007
  • Oct 16, 2007
what i did was take a ford g3 and have a alt. shop install a self exciteing regulator then all you need is one wire. the power wire that goes from the alt to the solonid(sp). make sure you use like 4ga wire and put a big enough fuse inline to handle the alt. I bought a wire kit from latemodel restoration supply (50resto.com) and did mine like that.
HISSIN50
34
129
Oct 16, 2007
  • Oct 16, 2007
Unless this is done for cost (the GM alts can be cheap), a 3G can be made essentially into a 2 wire alt (the power cable and the excite circuit. For the latter, accessory and cranking 12 volt feed run through a resistor).
The other two regulator wires get looped. Easy.
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 16, 2007
  • Oct 16, 2007
See http://forums.stangnet.com/showthread.php?t=646825 for 3G wiring. Check out my post #20 and look at the diagrams. It makes a one wire alternator seem silly. It's so easy a caveman could do it...
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
Electrical Mini-Starter Wiring
  • RekeHavoc
  • Jul 25, 2025
2K
Fox 5.0 Mustang Tech Aug 24, 2025
Mustang5L5
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
