got a problem, need help asap
  • Thread starter Thread starter bdub
  • Start date Start date May 9, 2008
bdub
67
kinston
May 9, 2008
  • May 9, 2008
just walked outside to start my car and run to the store, turn the key on and hear the fuel pump come on and all the lights in the dash, but car wont even try to turn over? no clicking or anything from the battery, checked it and it was good? could it be the starter has quit on me?
HISSIN50
34
129
May 9, 2008
  • May 9, 2008
Better chance that the starter interlock circuit is open. A bad or misadjusted clutch safety switch is the first place I check on things like this.
In the meanwhile, you could safely jump the starter solenoid. Be sure the E-brake is on and the car is in neutral.
bdub
67
kinston
May 9, 2008
  • May 9, 2008
just went back out there about 5 minutes ago and the car started up fine, i replaced the solenoid, power and ground wires about 3 weeks ago and it has acted fine since then until tonight?
bdub
67
kinston
May 9, 2008
  • May 9, 2008
still no idea of what caused this, starter is turning over like a champ again, just need 2 find the possible problem and get it fixed, because i dont like my stang being down and out
bdub
67
kinston
May 10, 2008
  • May 10, 2008
aight the car is doing it again, still same thing, can turn the key and nothing. i took a jumper wire to the solenoid and the car will turn over perfect? whats the next thing i should test to fix this?
woob
34
Tahlequah, OK
May 10, 2008
  • May 10, 2008
i had a 95 explorer where the little brushes in the starter burned themselves out, but only in certain positions... so when the car wouldn't start, I would try for a while, sometimes it would work, other times i'd wait 5-10 minutes and it'd start right up.
bdub
67
kinston
May 10, 2008
  • May 10, 2008
i have been messing with it all day today and it wont start unless you jump the solenoid, have checked the stuff on jrichkers no start check sheet, the starter will turn, but only if it is jumped at the solenoid
HISSIN50
34
129
May 10, 2008
  • May 10, 2008
How are you jumping the solenoid? If jumping the trigger post to the battery lug (tiny lug to the battery lug), then the solenoid is ok.
If you're jumping the two big lugs, you've only tested the starter and starter cable basically.
Put a test light on the starter interlock post (the small post at the top of the solenoid) and crank the engine. The test light should illuminate. I bet yours doesn't. If it doesn't, you know the issue is before the solenoid, namely the clutch safety switch, ignition switch or interlock wiring. The CSS is the place to go next (checking in/out voltage).
Good luck.
bdub
67
kinston
May 11, 2008
  • May 11, 2008
yeah i could jump the solenoid both ways and it would work, so now that it has stopped raining im gonna check the CSS, which wires do i need 2 connect to bypass it to see if that is my problem?
HISSIN50
34
129
May 11, 2008
#10
  • May 11, 2008
  • #10
There are only two terminals in the CSS.
For diagnostics, a blade fuse happens to fit real nicely into the terminals of the electrical connector. Again, just be sure the car is in neutral and the e-brake is on.
bdub
67
kinston
May 11, 2008
#11
  • May 11, 2008
  • #11
which connector should i put it in, one connector has all red/blue wires, the other a black, black/white, and two blue/yellow wires?
bdub
67
kinston
May 11, 2008
#12
  • May 11, 2008
  • #12
plugged a fuse into both connectors, still nothing, tested both with a test light and neither has power, so i took the plastic off around the column and tested the white/pink wire on the ignition switch. it has power when the key is turned
HISSIN50
34
129
May 11, 2008
#13
  • May 11, 2008
  • #13
Did you test the power into the CSS with the key turned to the cranking position?
If you have power at the white/pink wire egressing the ignition switch but no cranking power going into the CSS, you have an open in the wiring inbetween. Try wiggling the wiring as you go because it was an intermittant issue for you before.
bdub
67
kinston
May 11, 2008
#14
  • May 11, 2008
  • #14
tested it with the key turned on and the clutch pressed, got nothing, moved the wires all around and still have nothing
  • Mindseye007
  • Aug 16, 2026
Mindseye007
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
