  • SN95 4.6L Mustang Tech
Got a Stroker?
  • Thread starter Thread starter Rickyll7
  • Start date Start date Dec 16, 2005
1 of 2 Next Last
Rickyll7
718
  • Dec 16, 2005
I was curious to see what kind of numbers are being posted by people who have a 5L stroker with similar mods to those listed in my sig. I am preparing to pull my motor in a week and slap my heads on a Sean Hyland Motorsport stroker short block after the heads get a once over by Patriot. The pistons are 28 cc and should crank out a compression ratio of about 8.7:1, give or take about 2 tenths of a point.
I am realy interested in seeing any dyno sheets or just numbers with respective rpms if possible.
Any good ideas or comments are appreciated, Thanks!
edit:
Red 98 GT Coupe 5spd
Patriot Performance Stage II Heads, Comp Cams XE268H, BBK Tuned Length Shorty Headers, PI Intake, Demolet CAI, Magnaflow catback, Bassani o/r x pipe, Accel Coil Packs w/wires, ASP Pullies, SCT Eliminator Chip.
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 16, 2005
  • Dec 16, 2005
strokers do squat, bore makes a difference
Marks5.0!
640
San Antonio, TX
Dec 16, 2005
  • Dec 16, 2005
ill let ya know after the 1st of the year, 9:1cr 302 stroker, p&p heads, fr500 cams, 2.2KB and a 100 shot are going in mine.
im hopping for 550-600 on just the blower with 15psi in it.
98stangv8
1,036
fayetteville, nc
Dec 16, 2005
  • Dec 16, 2005
in my sig...click the rwhp for a direct link to the dyno sheet...
Rickyll7
718
  • Dec 17, 2005
Thanks, great info. Is there any more 5L strokers out there?
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Dec 17, 2005
  • Dec 17, 2005
Not a fan of anything built by SHM. He's been getting a lot of negative press as of late. I'd check out one of the other more reputable shops for a build, were I you.
....buy hey, it's your money.
LS2 KLR
452
Houston, TX
Dec 17, 2005
  • Dec 17, 2005
I just dynoed mine last week. It made alittle over 325rwhp with 23-24 degrees of timing and a 12.8 air/fuel. Had I gone with 10.5:1 compression and more aggressive tuning I'm sure it would have been more around 340rwhp.
TweekedGT
1,274
Alberta
Dec 17, 2005
  • Dec 17, 2005
306 Stroker bored .020 over. Don't have it in yet so I want to see your numbers . I've ordered stuff from SHM before for myself and clients. There is nothing wrong with their stuff. Their shipping sucks, I've never had anything show up on time, but their products are good.
J
jimfitzgerald
6,672
  • Dec 17, 2005
Mine is a MPH 302 stroker.
Rickyll7
718
#10
  • Dec 18, 2005
  • #10
Wow, awsome numbers! So what else would you all recomend for me to do next? A centerforce dual friction is already in the works with 24 lb injectors.
Rickyll7
718
#11
  • Dec 18, 2005
  • #11
ttt
TweekedGT
1,274
Alberta
Dec 18, 2005
#12
  • Dec 18, 2005
  • #12
If I were you i wouldn't waste my money on 24#'s. If you are going blower or turbo 24's aren't enough if you want to make real power, 450+. Get 42's or 55's and be done with it. It you're staying N/A you don't even need the 24's just keep the stock 19's. The centerforce is a good choice though, I have one and love it.
Rickyll7
718
#13
  • Dec 19, 2005
  • #13
What about a fuel pump? Do I absolutely need to upgrade? If so, I was thinking a T-Rex would be nice. What are everyones thoughts on that subject?
Rickyll7
718
#14
  • Dec 19, 2005
  • #14
ttt
Rickyll7
718
#15
  • Jan 7, 2006
  • #15
TweekedGT,
Have you installed your 302 stroker yet? If so, what were your numbers?
D
Dragstr05
643
Stafford VA
Jan 7, 2006
#16
  • Jan 7, 2006
  • #16
From what I understand these engines need more bore not stroke.
blackfang
1,290
Richmond, Va
Jan 7, 2006
#17
  • Jan 7, 2006
  • #17
I am not a fan of strokers as big bores make the power and more reliable.
First let's look at the stock modular bore and stroke. The stock bore is 3.552'' and the stroke is 3.543''. That stroke is HUGE already. A 351W has a 3.5'' stroke from the factory. They have an extra 73+ CID on the modular motors. This puts it in perspective on how extreme the stock stroke already is.
Now, combine that with a stroker kit and your piston starts leaving the bore. This is VERY bad at high RPMs as the piston becomes extremely unstable. Stroker motors just don't last. The HP/TQ gains are so minimal as well because the valves are still shrouded. The only time you want to use a stroker is when you have a turbo setup as turbos don't really like to rev high either and can benefit heavily from the slightest torque band increase. The reason these are so popular though is because you can use your stock block and you don't have to resort to using the more expensive aluminum block counterpart like you have to in a big bore.
Big bores are what make the REAL power. We're not just talking about HP either. They make great torque and LOVE to rev (which is just what a modular motor needs). Big bores increase the bore from 3.552'' to 3.7''. This is done by taking an aluminum block, boring out the sleeves that are already in it, inserting new, stronger sleeves and boring them out. There are 2 versions of big bores. One is the dry sleeve which doens't cost that much and can handle roughly 20 PSI on a blower. This is the one you want for a mild blower application or NA application. The other one is a set sleeve where they actually bore out the sleeve of the cylinder and insert a new heavy duty sleeve in. It is called a wet sleeve because the coolant is touching the sleeve; this allows for cooler temps. The wet sleeve can withstand basically anything you can throw at it. Aluminum blocks can be either wet sleeved or dry sleeved. Iron blocks can only be wet sleeved. As you probably guessed, wet sleeving is very expensive (about $1k more than normal dry sleeving).
Now, the reason the big bore benefits is this. On the stock motor, the valves are shrouded. This means that the cylinder isn't big enough to support the heads. Basically, the combustion chamber is bigger in diameter than the cylinder. Big bores fix this problem by unshrouding the valves. THIS, my friends, is the secret to why big bores are making the power and lasting as opposed to strokers. Remember this when you want to increase displacement. Oh, and don't even both with the 324'' big bore/stroker blocks as the rod ratio is all fudge up and they are just a problem waiting to happen
Rickyll7
718
#18
  • Jan 8, 2006
  • #18
So how long have the strokers out there been lasting on the street? And what exactly happens to them to cause them to fail.
J
jimfitzgerald
6,672
#19
  • Jan 8, 2006
  • #19
People who don't like strokers never had one. I've had mine for two years. I blew it up a couple times at the track before I switched to Modular Powerhouse and got my fuel system straightened out. It has run great for the past year on the street and on the track. A big bore may be better, but there is nothing wrong with a stroker and it will make more torque than a stock stroke.
Rickyll7
718
#20
  • Jan 8, 2006
  • #20
jimfitzgerald,
What exactly caused your engine to blow those few times?
1 of 2 Next Last
R
  • Locked
Expired 1990 White Foxbody With 331 Stroker, T56, And Much Much More
  • ramses_at_the_party
  • Nov 8, 2015
7K
Fox Body Mustangs For Sale (1979-93) Nov 24, 2015
Ryan Santos
R
G
  • Locked
2006 Ford Mustang GT D.S.S. 5.0L Stroker Crate Engine Street Legal Race Car
  • GunshipDriver
  • Sep 4, 2011
  • S197 Mustangs For Sale (2005-14)
7K
S197 Mustangs For Sale (2005-14) Oct 26, 2011
ranger2339
R
  • Locked
FS: 1993 LX 5.0 347 stroker reef blue/black int.
  • 87nitemare
  • Mar 9, 2010
19K
Fox Body Mustangs For Sale (1979-93) May 19, 2010
87nitemare
