Expired 1990 White Foxbody With 331 Stroker, T56, And Much Much More
ramses_at_the_party
Hello, my name is Ramsey Draskovich. I only joined this forum to sell this car; I'm about an hour out from Las Vegas but I will be willing to meet anyone in Vegas. Here's a list of the many parts my car has:
  • 331 Stroker
  • Compression 10..2..1
  • Forged Eagle Internals
  • Trickflow forged Flat Top Pistons
  • Eagle H-Beam forged Rods
  • Forged Eagle Crank
  • Maincap Girdle
  • ARP rod bolts
  • ARP head studs
  • ARP oil pump bolt
  • Anderson Cam n71
  • Forged Piston Rings
  • Trickflow Forged pushrods
  • Trickflow 1.6 roller rockers
  • Ford Racing lifters
  • Trickflow track heat Upper & Lower intake
  • 1-inch Phenolic intake Spacer
  • AC, Cats, and smog pump deleted
  • Steel MLS Head Gaskets, Copper Header gaskets
  • Anderson Powerpipe Cold Air Intake
  • Pro-M mass airflow sensor
  • BBK Throttle Position Sensor
  • Ford Racing 30Ib injectors
  • Walboro 255lph fuel pump w external BBK 190 lph fuel pump
  • BBK fuel pressure regulator
  • BBK fuel rails
  • Trickflow 170 cc aluminum twisted wedge heads worked to fit cam
  • Upgraded valves and valve springs to fit cam
  • Trickflow harmonic balancer
  • Moroso 7qt oil pan
  • Highflow Waterpump
  • Mishimoto 3 row aluminum radiator
  • Flexalite 3300 cfm single-blade fan
  • MSP GAL Ignition Box
  • Ford Racing 9mm spark plug wires
  • Spec 28 oz aluminum flywheel
  • Centerforce dual friction clutch
  • BBK long-tube ceramic coated headers, BBK X-Pipe
  • Basani Catback exhaust
  • Tremec T56 stage 2 Transmission
  • Adjustable BBK Clutch Cable, Adjuster, and Quadrant
  • Ford Racing throwout bearing and clutch fork
  • Ford Racing 26 spline input shaft
  • Stifler tubular transmission cross-member
  • Ford Racing Mini-Starter
  • After Market Rack and Pinion
  • Wilwood Proportioning valve
  • Hurst Shortshifter
  • Accufab 70 mm throttle body w spacer
  • Ford Racing Aluminum Driveshaft
  • Team-Z tubular front K-Member, Team Z tubular A-arms
  • Strange Coil-overs 12 inch 175Ib springs
  • Strange 10 way adjustable front struts
  • SVE Welded Subframe Connectors
  • Team-Z relocated single adjustable upper and lower control arms
  • Strange 2-way adjustable drag shocks
  • Ford Racing 4:10 Gears
  • 28 Spline moroso forged axles
  • Ford Racing Tracklock
  • Carbon Fiber Differential clutches
  • Ford Racing Aluminum Differential Girdle
  • Swarbar
  • Team-Z rear drag springs
  • Cervini Rear Cobra Bumper
  • Cervini SVO Cobra R hood
  • Cervini Stalker front bumper
  • SVE Ultra smoked fog lights and Head lights
  • Ultra Smoked Tail Lights
  • Cobra R Racing Seats
  • Phantom Autometer Gauges
  • FR500 Wheels, 17x9 front, 17x10.5 Rear
  • Moroso forged racing Spindles 5 lug, ‘03 13 inch cobra drilled and slotted brakes
  • Mickey Thompson 315/35/17 ET Street Tube Drag Radials for the rear
  • SportComp 2 255/40/R17 for the front
  • Polyurethane motor mounts and tranny mount
  • SCT tuner chip
  • All new carpet, headliner, door panels
  • Billet buttons and E-Brake
  • Relocated battery w Taylor Setup
  • Newly aligned and new front tires
    This car is in tip top condition. The engine was put in one year ago and hasn't had many miles put on it since. Only synthetic Royal Purple oil has been used along with 91 octane gas from Shell. There is a ton of time and money put into this car so please take my asking price of $9,000 seriously. My phone number is 702-379-0555. I'm looking for everyday drivers such as tacomas, jettas, camrys, etc. Feel free to contact me. Here's a few pictures.
That is a beautiful rig. Have you timed your 1/4? What's the hp? Interior pics still coming? I'm on the hunt and love everything I see, just not sure if I'm going to spend that much on my fox.
The guy who had it before me ran mid 11's. But that was before he dropped this engine in. It has not been run with the 331 and new suspension. Ill get back to you on the HP but from what I remember it was around 400 to the wheels. I've been too busy to vacuum out the interior but I will get those pics uploaded, now that I know that there's some interest.
  • 331 Stroker
  • Maincap Girdle
  • ARP rod bolts
  • ARP head studs
  • ARP oil pump bolt
  • Anderson Cam n71
  • BBK fuel rails
  • Swarbar
  • SCT tuner chip
    This car is in tip top condition. The engine was put in one year ago and hasn't had many miles put on it since. Only synthetic Royal Purple oil has been used along with 91 octane gas from Shell. The only problem I've had includes a high idle every once in a while; I know it's one of the sensors or possibly the tune because it hasn't done this until it got cold. There is a ton of time and money put into this car so please take my asking price of $11,000 seriously. My phone number is 702-379-0555. I'm looking for a gas-friendly car such as a TDI jetta or a car for college. Feel free to contact me. Here's a few pictures, I will include more of the interior tomorrow I just wanted to post as quick as I could.
hi Ramsy, if you're willing, i will pay close to your asking price.. only problem is i will have to pay for it in around 1 years time from now, if you're interested and willing to hold it for that long, then feel free to respond
