  • 1994 - 1995 Specific Tech
Got the 3.90s in?
  • Thread starter Thread starter rudeone707
  • Start date Start date Apr 6, 2004
R
rudeone707
1,829
Fairfield, Ca
Apr 6, 2004
  • Apr 6, 2004
Finally got my 3.90s and ,wow, the car freakin pulls way hard now. traction is now an issue in first gear. The guy that helped me install the gears was a little skeptical about the way the teeth were shaped, but then was surprised that they went together so smoothly. I also have no gear whine. So whoever said that the 3.90s would whine was wrong. I think that its just more the installer. The only thing i have to get now is a speedo gear and a new trak lock.
What speedo gear should i go with?
Black Stampede
1,811
Grand Rapids, MI
Apr 6, 2004
  • Apr 6, 2004
Bite the bullitt and get a speedcal. They are worth the money.
AznStanger3v
2,026
Northern VA
Apr 6, 2004
  • Apr 6, 2004
technically, they dont make a speedo gear for 3.90s. They have the 23 tooth for the 4.10s and 3.73s. Id say get the 23 tooth AND bite the bullitt and get a speedcal.
R
rudeone707
1,829
Fairfield, Ca
Apr 6, 2004
  • Apr 6, 2004
what exactly is a speedcal and where can i get one? can i install it myself?
R
rockin_rick
968
Apr 6, 2004
  • Apr 6, 2004
The correct speedo gear setup is 6 tooth in the trans and 19 on the sensor. You won't get it very close with out a speedcal or changing the output shaft gear in the trans tailhousing.
Rick
Joes95GT
3,132
Delaware
Apr 6, 2004
  • Apr 6, 2004
Rick
That would get close. I'm going to agree with the majority here and say that I don't believe there is a combination of drive/driven gear made for a car with a 3.90 gear. I personally would get the Speedcal if I did it all over again. It compensates for different size wheel and tire combos and can be changed for when you go to a steeper gear . The Speedcal can be purchased from Dallas Mustang. They have install instructions on the website and the install seems incredibly simple.
Joe
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Apr 6, 2004
  • Apr 6, 2004
:worship: anything > 3.73's
RC
R
rudeone707
1,829
Fairfield, Ca
Apr 6, 2004
  • Apr 6, 2004
RC
94GTLaserRC
11,178
Apr 6, 2004
  • Apr 6, 2004
rudeone707 said:
Youre the one that put them in, not me!
RC
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Apr 6, 2004
#10
  • Apr 6, 2004
  • #10
RC what gears do you have, stock?
GTJake
3,049
Ann Arbor, MI
Apr 6, 2004
#11
  • Apr 6, 2004
  • #11
He's got 3.73's.
Jake
mytight95
2,605
Dothan,Al
Apr 6, 2004
#12
  • Apr 6, 2004
  • #12
dude i think you misunderstood his post, he was saying praise anything over 3.73's. I have the 4.10's, and i will tell you however, that if you have a five speed be very careful the first time you drive it itn the wet with the gears.
lol
jason
JJ95GTID
1,141
Phoenix, AZ
Apr 6, 2004
#13
  • Apr 6, 2004
  • #13
Brothers Performance Warehouse also sells the Speed calibrator ($84.99). It says for 99-04 Mustangs but is the same unit as DM's. I run the 23 tooth gear with 3.73s' and it is just about dead on. If I went with 3.90s' or greater gear I would have bought the Speed Cal.
R
rockin_rick
968
Apr 6, 2004
#14
  • Apr 6, 2004
  • #14
Joe
That's not true. The majority is wrong then. The method that most here use is Hanlon's calculator. It is not accurate. Specifically, it does not calculate revolutions per mile for the given tire size accurately. People here believe it's data, and spread that disinformation like wildfire. I'm not trying to discredit anyone, just trying to clear up this stangnet misconception.
The formula to determine speedo gears is:
rear gear ratio X drive gear teeth X tire's revolutions per mile / 1000 = driven gear
This is a well known formula and is referenced in the Ford Racing 2004 catalog on page 129.
These examples assume a tire with 810 revs/mile. This is a common size for 245/45-17's. For this example, this is not important - just that the tire size stays consistent between examples.
so with 3.90's:
3.90 X 6 X 810 /1000 = 18.954
compared to stock 3.08's:
3.08 X 8 X 810 /1000 = 19.9584
The closer that you get to a round number, the more accurate the speedo will be. The farther off, the less accurate. So for 100% perfect accuracy, you'd need a 18.954 toothed gear. Obviously, gears don't come in fractional sizes. You have to use the closest round numbered one.
The calculations show that both stock gears and the 3.90's will have nearly identical accuracy. If you assume that the speedo is calibrated to the stock 3.08/8/20 setup and takes in account for the slight inaccuracy, you have to assume that the 3.90/6/19 setup will also take that slight inaccuracy in account, and be as perfect as you can get.
This is based on math, not myth.
I discussed this in greater detail here-
http://forums.stangnet.com/showthread.php?t=389857
and
http://forums.stangnet.com/showthread.php?t=392055
Rick
mytight95
2,605
Dothan,Al
Apr 6, 2004
#15
  • Apr 6, 2004
  • #15
yeah what he said
94GTLaserRC
11,178
Apr 7, 2004
#16
  • Apr 7, 2004
  • #16
Like Jake said...it's in my sig.
BTW, I have said it before NUMEROUS times and Ill say it again.
The Single best SOTP I ever felt leaving the shop aside from the Vortech install was when I got the 3.73's.
With an AODE, the only reason I didnt do 4.10's at the time was I did a LOT of hwy driving.
ANYONE mustang-loving enough to be in this forum and NOT have gears is cukoo!
RC
Joes95GT
3,132
Delaware
Apr 7, 2004
#17
  • Apr 7, 2004
  • #17
Rick, the reason I said that the 19/6 combination would get the car close, but not spot on is because I thought Ford didn't make a 19 tooth speedometer gear. Upon further research, I found out they do. You were right . And I thought I knew it all...
Joe
R
rudeone707
1,829
Fairfield, Ca
Apr 7, 2004
#18
  • Apr 7, 2004
  • #18
lol
jason
i did misunderstand his post. I figures RC ALWAYS has something sarcastic to say. My Bad
95stocker
236
Rochester
Apr 7, 2004
#19
  • Apr 7, 2004
  • #19
I know it's not my post, but will the 23 tooth speedo gear be the closest I can get with 3.73's?
R
rockin_rick
968
Apr 7, 2004
#20
  • Apr 7, 2004
  • #20
Without changing the 8 toother in the trans, then yes.
If you go to a 7/21, that will get you closer. Or, I suggest, a 6 and a 18. That will be just as close as the 7/21, but will allow other common rear gear changes in the future (such as 3.90, 4.10) and only require changing the speedo gear to get resonable accuracy.
Rick
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
C
Shifter lever arm issue
  • chris1993
  • Jan 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 24, 2026
Rcdgl
R
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
