granada disc brake question(help)
  • Thread starter Thread starter pazcarguy
  • Start date Start date May 16, 2005
P
pazcarguy
65
Pittsburgh, PA
May 16, 2005
  • May 16, 2005
Just purchased a granada disc brake setup for my 66 coupe from individual who has decided to take another route. Kit had in it rotors/calipers/spindles/pads and bearings. Laurel mountain mustang recommended a 67 master cylinder so I purchased this from them for 39$ new. Problem is that I have no granada proportioning valve and can't seem to locate one. After doing research, I found that I can tee front brake line just after master cylinder and put a manual (Summit) proportioning valve for rear brakes. Anyone do this and if so, pros/cons? Keep in mind that i cant locate the stock proportioning valve new, it is discontinued. Brian
sanyarcosean
9
Red Lion PA
May 16, 2005
  • May 16, 2005
I think your going to find that this is a fairly common set up. I have the Summit Adj Prop Valve in my 1966 Mustang daily driver/autocross car and have had no problems with it.
Good Luck
Sean
Hack
1,945
Minneapolis
May 16, 2005
  • May 16, 2005
The manual proportioning valve is the way to go. It's by far superior to using the Granada one. I have the Granada one, and my rears lock first in a panic stop on my '70. Those are the pros, I am not aware of any cons.
One other thing, after a year of running mine, I finally realized that my master cylinder is missing the residual pressure valve for the rear drums. This makes my pedal soft on the first try. Make sure your MC has the residual pressure valve, or buy one for the rear drums.
68 manual disc/drum master cylinder
  • Butchd88
  • May 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2026
Butchd88
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Today at 2:14 PM
rednotch
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
F
5 lug disc brake pad help
  • Foxrider714
  • Nov 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
KRUISR
