Markus Member Feb 29, 2004 238 2 19 germany Nov 22, 2006 #1 Nov 22, 2006 #1 Hello, can i attach the main ground wire (direct from battery) on my aluminium cylinder heads or must i fix it on the block? Thank´s for input.... Markus
jrichker StangNet's favorite TOOL In Remembrance. Thank you for your contributions Mar 10, 2000 27,512 2,813 234 Dublin GA Nov 22, 2006 #2 Nov 22, 2006 #2 The heads will do, the block is better. The stock location for the ground is down in front of the oil pressure sender port. Avoid using the bolts that go into the timing cover for a gound. They tend to corrode and make poor grounds.
