  • SN95 4.6L Mustang Tech
GT engine knocking noise advice..help!!!!
  • Thread starter Thread starter orlandogt310
  • Start date Start date Feb 24, 2008
O
orlandogt310
  • Feb 24, 2008
ran low on oil and my engine is now knocking!
what do you guys recommend me to do: options...??
D
darkside03gt
851
Sacramento CA
Feb 24, 2008
  • Feb 24, 2008
assuming you've put oil in it. its probably damaged to the point of needing a rebuild.
the98stang
2,408
Clovis, CA
Feb 25, 2008
  • Feb 25, 2008
You need to do a compression test and leak down test. How low did you run the oil? Change the oil and look for metal flakes. You can use a magnet to find metal shavings in the oil.
BLOWN00GT
55
  • Feb 26, 2008
i spun a bearing once... you possibly did too... does the noise come and go or is it constantly there... mine was not always noticeable... but either way you would need a bottom end rebuild at the minimum...
it was a very low tone knock...
do the valve seals in the head as well... take that one from me... i learned my lesson
screamin gt
5 Year Member
Apr 9, 2007
393
central CT
Feb 27, 2008
  • Feb 27, 2008
and if you rebuild, may as well use forged parts. won't cost that much more in the end. wished I listened to everyone on that one, not that I have any real need for the parts, just sort of a could've had em for about the same price.
04YELLOWGT
1,135
Indiana
Feb 27, 2008
  • Feb 27, 2008
Yep most likely hurt the motor, do a compression test to make sure. Then most likely get ready to fork out some dough.
Like everyone said if you plan on doing any performance mods to it you might as well go forged, if its just a stock DD and you plan to keep it that way then just do stock rebuild or look for a wrecked GT to pull the motor out of.
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
Electrical Dash wiring
  • RileyDymond
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 19, 2026
RileyDymond
C
Knocking after pull- went away?
  • Connormcclark
  • Oct 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 6, 2025
gkomo
