  • SN95 4.6L Mustang Tech
GT idle "feels" rough help
  • Thread starter Thread starter HoustonGT
  • Start date Start date Dec 1, 2005
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Dec 1, 2005
  • Dec 1, 2005
Hey guys. I just picked up a 2000 GT with 41k miles and the idle on the tach is as smooth as can be. No jump in rpm's or anything. The problem i have is that the idle feels rough through the shifter and kind of through the seat. It makes my leg move a bit. Also, if i listen to the exhaust it kind of pops a bit every 1-2 seconds as if i have flows or something but my exhaust is bone stock. BTW, im pretty sure its not misfiring or anything because the car runs VERY strong. Could it be that i just of need some new plugs? Thanks
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Dec 1, 2005
  • Dec 1, 2005
You should go through it assuming that it did not have maint. And yes, this includes replacing plugs.
Also, clean MAF and reset PCM.
You need to do some serious searching and researching.
Start by reading every word on this website:
www.bullittarchive.com
bham_gt
94
Birmingham, AL
Dec 1, 2005
  • Dec 1, 2005
Maybe run some fuel injector cleaner through it too.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Dec 1, 2005
  • Dec 1, 2005
Yeah, Seafoam...
jasonh_86
I
May 20, 2005
1,156
Arkansas
Dec 1, 2005
  • Dec 1, 2005
Seamfoam!
2002GreyGT
481
Raleigh, NC
Dec 1, 2005
  • Dec 1, 2005
I have heard seafoam is good but never used it yet.
I suggest do a really good maintence on it.
Plug change
clean MAF
Fuel system cleaning
Oil change - duh?
Air filter? If its a K&N they may have over oiled it.
Reset PCM!
After running my GT hard for a while I'll get a rough ilde but goes away.
~K
topgunz_1
100
Louisiana
Dec 1, 2005
  • Dec 1, 2005
its a mustang, not a lincoln. brand new GT's i've driven have a bit of viration
Green Flea
28
California
Dec 1, 2005
  • Dec 1, 2005
If you have the A/C on, it changes the rpm a little to run the compressor. It's Normal.
V
VividDreams
200
Lebanon County, PA
Dec 1, 2005
  • Dec 1, 2005
yeah it sounds normal to me too. but i guess a quick tune up like abouve noted couldnt really hurt anything...
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Dec 1, 2005
#10
  • Dec 1, 2005
  • #10
Aight, thanks guys. I knew i had to run some injector cleaner and change plugs, just makin sure it wasn't anything major. I guess my 99GT just ran a bit smoother
03greygt
#11
  • Dec 1, 2005
  • #11
Do you have a k&n? If you do the oil from the filter gets in the mass airflow sencor and makes a rough idle. I suggest cleaning the sensor.
Smokeurhonda
457
Maryland
Dec 1, 2005
#12
  • Dec 1, 2005
  • #12
Dude...it's normal...mine does the same ****. Don't worry bout it.
SLY GT
105
#13
  • Dec 1, 2005
  • #13
ditto
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Dec 1, 2005
#14
  • Dec 1, 2005
  • #14
if you tune it up and it drives fine with no power loss, everything should be ok. if it was a plug or COP, you'd feel it during normal driving.
also, check to see if the previous owner put in aftermarket motor mounts.
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Dec 1, 2005
#15
  • Dec 1, 2005
  • #15
as long as it isnt bogging, it prob. isnt something too major.
stangGT97
1,299
Boston area, MA
Dec 1, 2005
#16
  • Dec 1, 2005
  • #16
ya mine is a little rough at idle. i changed the plugs and it got worse, go figure, the plugs like to loosen themselves
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
  • Gulftown980x
  • Jul 29, 2026
squeak93
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
