gt40 topend plus spray ='s ???
mhorn0817
69
just wondering what kind numbers and times you gus think id be looking at with
-gt40 upper and lower manifolds
-gt40p heads with FMS 1.6 rr's, brand new TFS valve springs and retainers, & stock pushrods.
-65mm tb
-bbk cold air intake
-headers , catless xpipe with flowmaster dumps
-subframe connectors
-410 gears
-compucar wet nitrous system 100 shot
all this is a gutted 87 coupe 5 speed with no smog,no ac, no ps
think i should do or change anything else?
want to run in the 12's, 11's would be awesome! , on sticky tires also
I have a TFS Trackheat intake and an AOD with the stock converter. Other than that the mods are pretty close. With a wet plate kit the car went 12.72@109. With a converter I am pretty sure it should go faster. The only other prob is that I am almost out of gear at the top end.
Edit: The nitrous comes on at 3k and off at 6k with a window switch.
-65mm tb
-410 gears
dont forget injectors and a cam... id say your good for 12.2-12.4
Why would he need to change injectors? If it were a dry kit then yes but with a wet kit the fuel jet supplies the extra fuel needed for the nitrous. I run stock 19lbers with my set up and no issues.
Like I said earlier I run a TFS stage 1 cam. Pretty good OTS cam. If you want you can always get a custom cam but them are more expensive, worth the money but I don't know what your budget is. If you a cam isn't in your budget then the stocker will work ok.
so do i need cam and injectors or no? trying to do a budget build so, tryin to go fast for cheap. mainly a street track car, not a daily driver,just a playtoy
yes the kit is a wetkit
