Various sources will result in 300-400 extra dollars in my pocket this month. I want to spend it on my mustang but need a little guideance. If you give advice, please give a brand and the difficulty on the install. I've got a decent amount of mechanical skill (just replaced the injectors and the car still works ). Here are the choices:
1. Gears possible 3:27 or 3:55. I don't use the car for any racing. It has 2:73. The rear end is leaking and is in need of a new gasket....while I replacing the gasket I could replace the gears.
2. Short Shifter. This is the first 5sp I've owned (not driven). It sure does seem like it takes a long time to shift from one gear to the next.....It could be my driving but I think its more the shifter.
3. Rear upper and lower control arms. The car has over 200k with the stock stuff (stock bushings). Its getting time to change.
4. Fix random little things on the interior.
5. Pocket the money and watch it dwindle away on nothing like cokes and food at work.
