Guide me Stangnet brethren
dec322
401
Bham AL
Various sources will result in 300-400 extra dollars in my pocket this month. I want to spend it on my mustang but need a little guideance. If you give advice, please give a brand and the difficulty on the install. I've got a decent amount of mechanical skill (just replaced the injectors and the car still works:) ). Here are the choices:
1. Gears possible 3:27 or 3:55. I don't use the car for any racing. It has 2:73. The rear end is leaking and is in need of a new gasket....while I replacing the gasket I could replace the gears.
2. Short Shifter. This is the first 5sp I've owned (not driven). It sure does seem like it takes a long time to shift from one gear to the next.....It could be my driving but I think its more the shifter.
3. Rear upper and lower control arms. The car has over 200k with the stock stuff (stock bushings). Its getting time to change.
4. Fix random little things on the interior.
5. Pocket the money and watch it dwindle away on nothing like cokes and food at work.
option 5 sucks:D
i'd say gears, 3.55.......you'd notice a difference and still be able to drive all you want on the freeway.
you'll have enough money to have them installed at a shop, which unless you've done it before or know some one who's done it before would be the best idea.
as for suspension, sounds like it's got some miles on it, kinda hard to say weather new bushings or new controll arms would be best depending on what your plans for the car are in the future. also, do you have sub frame connectors yet?
is the engine and exaust stock??
with that many miles before you do alot make sure the basics are in good order, brakes, basic tune up, shocks, steering and rack, etc. if all thats good, go for the gears first.
or, a shifter is nice too (i need one as well) you could always buy a shifter and take the rest and put it into the other stuff if it needs it.
The engine has been rebuilt and has about 4k. It was bored .30 over but everything else about it is stock. Its got a MSD Billit Distributor, MSD coil, BBK Headers, Off Road H-Pipe, Flowmaster Mufflers, Alum. Driveshaft.......
Yes, I have subframe connectors. I want to look at the torque boxes probably this sat. Shocks and stuff are around a year old. Brakes are good but I would like to get some more money one of these days a do a 5 lug conversion with rear discs.....one day.
My plans are a little wierd right now. The car is a daily driver and will be for a few years. I don't need something to race but I do like to give it a little gas....probably more than I should.
I forgot to mention the choice of: getting a 3g alt. I bought the car with a smaller crank pulley and it drains a little w/ all the lights and stuff on.
Are gears hard to install if I do it myself?? I'll look into pricing on the install.
Its not that its all that hard but if you don't have the right tools and whatnot to set the backlash you will trash your brand new gears.
There are websites and books out there to guide you through a gear install. Personally, it's a job that I pay to have done.
If it were my car and I had some "extra" money to throw at the car, I would focus on things that need fixing. Suspension / Charging / broken bits and pieces here and there. Try finding a short throw shifter on eBay. Cheaper than new, but still works the same. You probabaly will not have enough for the gears. But if you have a timing light you could bump the timing for a little more pep from the car.
Well, I've made my decision. I'm going to focus on all the little things: headliner, door handles, door panels. Maybe buy some dynomat. With the leftover money I'll see about getting a 3g alt.
If you really just want a good alt., and aren't looking for a lot of show, check out e-bay. I've seen several 3g alts that went for $35-50 plus shipping. I don't know what it would run you for a new one at the local parts store.
