nick6690 Member Mar 2, 2008 147 1 17 McDonough, GA Feb 27, 2009 #1 Feb 27, 2009 #1 My untuned H/C/I car runs like an animal after 4 grand but under normal acceleration at around 2 to 3 grand it sputters and misses pretty bad. Is this normal? How much does it cost to get it tuned? Mods are in sig.
1991notchbackLX Active Member Dec 25, 2007 1,483 47 48 New York Feb 27, 2009 #2 Feb 27, 2009 #2 i'd figure between $500 and $600 for a tune with an SCT chip burned, that seems to be the going rate for a chip/tune/minimum three pulls mine cost around $600, but then again this is NY, not Mcdonough, GA WELL worth every single penny though
nick6690 Member Mar 2, 2008 147 1 17 McDonough, GA Feb 28, 2009 #3 Feb 28, 2009 #3 Is it normal for it to run like this?
strtrcr50 New Member Jun 21, 2006 0 4 0 Previously from Dirty Jerzey exit 7a Feb 28, 2009 #4 Feb 28, 2009 #4 Big cam for that motor, isn't it? Do you have a stroker? What compression pistons?
nick6690 Member Mar 2, 2008 147 1 17 McDonough, GA Feb 28, 2009 #5 Feb 28, 2009 #5 bottom end is stock but the pistons were notched for valve reliefs
strtrcr50 New Member Jun 21, 2006 0 4 0 Previously from Dirty Jerzey exit 7a Feb 28, 2009 #6 Feb 28, 2009 #6 While I wouldn't expect it to miss, I wouldn't expect much down low. What mass air are you using?
