  • SN95 4.6L Mustang Tech
H-Pipe Install HELP QUICK!!!!
  • Thread starter Thread starter lockw33d
  • Start date Start date Dec 27, 2005
lockw33d
64
  • Dec 27, 2005
How do i get teh front o2 sensors off, fo i unclip them, or do i need to unscrew them. I cant see how i can get a wrench in there to unscrew them if thats what i have to do. Also what size is that head, the largest wrench ive got is a 3/4 and it dont fit them?? What gives. HELP QUICK!! THanks
ALVARADO302
Banned
Nov 2, 2004
69
Los Angeles
Dec 27, 2005
  • Dec 27, 2005
Use an adjustable wrench that worked for me on my previous installs...Its pretty easy once you got some room to reomove it but its pretty tricky. Good luck
O
OleYellarGT
64
Charlotte, NC
Dec 27, 2005
  • Dec 27, 2005
unplug them first so you will not damage the wires, should be about a 7/8....I think.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Dec 27, 2005
  • Dec 27, 2005
the size on that is a 22mm and yes you can just unscrew them but make sure you retighten them good but i would recommend just unclipping them
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 27, 2005
  • Dec 27, 2005
Disconnect the battery if you havent already!!!
trailblazr81
571
Hollister, Cali
Dec 27, 2005
  • Dec 27, 2005
I unplugged the O2's, then removed H pipe. Set H pipe on bench then used a boxed end wrench to remove O2's. You can use an adjustable, I think I used a 7/8.
lockw33d
64
  • Dec 27, 2005
Ok guys, got the o2's out but now got another problem. Looks liek the guy lied to me this pipe didnt come off an 99-04, b/c the passenger side o2 bung is too far away from teh o2 sensor. i need about another 2 inches or wire. can i swap it out with another 02 sensor orr a different model that might be longer. or can i splice into those wires and try to redneck engineer it???? HELP PLEASE!!
can i plug one of my MIL eliminators into it to get the distance i need???
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Dec 27, 2005
  • Dec 27, 2005
might be an 04' H pipe more than likely you will need O2 extensions
lockw33d
64
  • Dec 27, 2005
where do i get these extensions, can i get them from advance auto??? CAn someone post a pic of a MAC 04 Hpipe so i can try to compare. It had to hangers that i had to cut off along with alittel plate with two holes on the passenger side..
OK FOUND SOME ON MUSTANG TUNING.COM BUT THEY AR $40 CAN I GET THEM ANYWHERE ANY CHEAPER??
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Dec 27, 2005
#10
  • Dec 27, 2005
  • #10
what year is your car?
lockw33d
64
#11
  • Dec 27, 2005
  • #11
2000
FOUND THESE
https://www.rpmoutlet.com/ezRetail/search/view.php?msg_id=1060
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Dec 27, 2005
#12
  • Dec 27, 2005
  • #12
those will do
lockw33d
64
#13
  • Dec 27, 2005
  • #13
OK GOT A SET FROM MUSTANGTUNING.COM. USED THE STANGNET COUPON BUT THEY SAID THEY WERE FOR 2004, THEY'LL WORK WONT THEY???
sgarlic
3,085
Dec 27, 2005
#14
  • Dec 27, 2005
  • #14
Yes.
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
