ha another check engine...
I messed around with the ways shown on past threads with the harness and watch the dummy light blink. Can't seem to get it to work, unless I'm just retarted. I need that handheld or somthing.Ya I will dump the codes asap was just checkin if that was a common thing,but now its stuck on all the time so im choiceless.
Dont know if your problem is the same as mine but when mine would do that I went and bought some of that dielectric grease and put it on all of my connections and it stopped, I did the salt and pepper shakers, maf, tps, ect, basically everything I could see, and it stopped??:shrug:
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
attachment.php
89 through 95 cars have a working Check Engine light. Watch it instead of a test lamp.
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
o.k now I bought the dam code reader.Now it just stays solid no blinking I even waited bout 15 mins nothen happend somtimes car wouldn't even start with it hooked up and when it did start after disconecting it i'd reconnect and it would run rough.any advice???
it never fails wit this stuff prob harness fried or somthen how it usually goes for me.....
Ok just went out there again to give it another try. I hook it up its just a normal count the light type scanner "Actron"brand. If its all connected it will run on the hold position now if I click it up to the test position car will die out immedietly.please somonme help i need to find whats wrong with her.Shes all fubar'd up.PLEASE HELP
I'm bout to kill somone....Where you at Jrichker? did it again some ordeal this car is bout to be sold if this don't change car runnin like crap!!please please helpi searched the threads and no one has this problem"tipical"in my case theres always a loophole.....sorry for all the replys I just have nothing but time right now just sittin here waitin for you kind people to help before car goes into Chicago river.
Computer will not go into diagnostic mode on 86-90 model 5.0 Mustangs
Disconnect the battery positive terminal before making any resistance checks.
The voltage drop in the ground cable will cause incorrect resistance readings.
How it is supposed to work:
The black/white wire (pin 46) is signal ground for the computer. It provides a dedicated
ground for the EGR, Baro, ACT, ECT, & TPS sensors as well as the ground to put the
computer into self test mode. If this ground is bad, none of the sensors mentioned will work
properly. That will severely affect the car's performance. You will have hard starting, low power
and drivability problems.
Since it is a dedicated ground, it passes through the computer on its
way to the computer main power ground that terminates at the battery pigtail ground. It should
read less than 1.5 ohms when measured from anyplace on the engine harness with the battery
pigtail ground as the other reference point for the ohmmeter probe.
What sometimes happens is that the test connector black/white wire gets jumpered to power
which either burns up the wiring or burns the trace off the pc board inside the computer.
That trace connects pins 46 to pins 40 & 60. Only an experienced electronics technician can open
the computer up & repair the trace if it burns up and creates an open circuit.
The STI (Self Test Input ) is jumpered to ground to put the computer into test mode. Jumpering
it to power can produce unknown results, including damage to the computer. The ohm test
simply verifies that there are no breaks in the wiring between the test connector and the computer input.
How to test the wiring :
With the power off, measure the resistance between the computer test ground
(black/white wire) on the self test connector and battery ground. You should see less than
1.5 ohms.
attachment.php
If that check fails, remove the passenger side kick panel and disconnect the computer
connector. There is a 10 MM bolt that holds it in place. Measure the resistance between
the black/white wire and pin 46 on the computer wiring connector: it should be less than
1.5 ohms. More that 1.5 ohms is a wiring problem. If it reads 1.5 ohms or less, then the
computer is suspect. On the computer, measure the resistance between pin 46 and pins
40 & 60: it should be less than 1.5 ohms. More that that and the computer’s internal
ground has failed, and the computer needs to be replaced.
If the first ground check was good, there are other wires to check. Measure the
resistance between the STI computer self test connector (red/white wire) and pin 48 on
the computer main connector: it should be less than 1.5 ohms. More that 1.5 ohms is a
wiring problem
The following is a view from the computer side of the computer wiring connector.
Check out the diagram and notice all the places the black/white wire goes. Almost every
sensor on the engine except the MAF is connected to it.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
(website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine
ok Jrichker I checked the ohms on the #46 wire off of the diagnostic port came up 1.83ohms with battery (power)connected,and 2.02ohms with battery(power) off. I'v also checked the ground on the battery itself which was relocated to trunk and grounded to where the fuel pump shut off is at(like the very rear inner trunk metal)is that o.k? It came up 1.03ohms.What now?what do you think?
AHHH!o.k I took the computer out and looked at the harness connector to find out pin 46,37,38,57,&60 are missing pin 40 is there but the others have no wire running to the connector at all!!wtf car ran like a champ till now why all of a sudden?I am so fubar whats this gana mean new harness?:mad:
Are you sure that you counted the pins correctly? They are mirror imae reversed if
you try and count then from the wire side of the connector. Use the wiring diagram
with the wire colors I posted to verify your findings.
reference voltage
I looked up a code for my '90 LX check engine light coming on that says 'EGR Vref low'..... It looks by the drawing that this Vref coming from the MAP, the TPS and the EGR vlv all come together and then back to the computer. Is the EEC4 smart enough to know where on this Vref that the problem is??? Also, when I go checking for grounds/shorts on this wire, do I disconnect battery power?
Thanks all.
dude i'm pretty sure. I looked last night.I'll look today what is reversed i looked at the harness just as its on the diagram you sent and i'm missing a bunch of wires.Is there any wires missing or soppose to be missing.
* pin 46 is black /white?? Can somone send a picture of their harness? ill post a picture in a few minutes
o.k now I got it all writtin down.Up front on the diagnostic port (black/white wire)#46 it reads 2.17ohms with the battery off(I don't know if that makes a difference).Now i
I took the computer out and checked the black/white wire(pin46) with the computer connected(if computer not connected it don't show me any ohm reading) it reads 2.17 ohms(battery off as well).Jrichker you said if it is over 1.5ohms there is a wiring problem?correct? where do I go to now?
oh ya,I did look at it backwards you were right.lack of sleep the night before I guess..hah
