  • SN95 4.6L Mustang Tech
Hard Starting
  • Thread starter Thread starter SyberSaint
  • Start date Start date Jan 22, 2007
SyberSaint
252
San Antonio, Texas
Jan 22, 2007
  • Jan 22, 2007
Hello Crew,
I am having some starting probelms... It seems that when I go to start my car, it has a hard time starting. It will turn over real good, and seem like it wants to start and then die. When I go to restart it, sometimes I also hear a backfire. Once it is started, it runs prefectly. Seem like it might be some fuel issue......Any help is appreciated.
Thanks,
Dale
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Jan 22, 2007
  • Jan 22, 2007
What's up Dale, I just moved here to Florida from New Braunfels. Got your car tuned by Mr. Mike huh? LOL, jusk kidding Mike is a great guy and one of the most knowledgable out there. I knew Mike when he first opened up Texas Jam over there in that little 1 bay shop over on Perrin Beitel.
Anyway, have you scanned the car to look for any codes? Have you checked things like fuel pressure, plugs, vacuum leaks?
SyberSaint
252
San Antonio, Texas
Jan 22, 2007
  • Jan 22, 2007
Hey Kevin, what's up man. What in the world took you to Florida anyway. That is a long way from home... Anyway, I have not done any of the things that you have mentioned because I wanted to get some input from the forum first, so as to not go into this blind... I have never used Mike, but the previous owner of my Saleen had it tuned there. He actually has a new shop right of of Judson Rd., right by Jordan Collision Center. I hear it is a pretty nice shop.... Any of you have any thoughts on this probelm, please chime in...
Dale
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Jan 22, 2007
  • Jan 22, 2007
The first thing I would do is get it on a scanner. Then if you do have codes, you you know where to start looking. For instance, sometimes when a motor is difficult to start but then will eventually start and then run fine is an indicator of lazy O2 sensors. There are dozens of O2 sensor specific codes that would point you in the right direction.
Another example would be your ECT(engine coolant temp) sensor. If that sensor were malfunctioning it could severely throw off your fuel trims upon startup.
If it were a fuel related issue, chances are you would experience problems at part throttle and WOT as well.
Checking for codes may help to determine whether or not you may have a vacuum leak as well.
SyberSaint
252
San Antonio, Texas
Jan 22, 2007
  • Jan 22, 2007
Thanks for the starting point Kevin. I sure appreciate it.. I dont know how active you were in SA, because you may have seen my car before. It belonged to Luis before he traded it for an 03 Cobra. He is an active member in San Antonio chapter of www.UnitedStangs.com. Take care...Dale
blubullett
535
Modesto, CA
Jan 22, 2007
  • Jan 22, 2007
My car used to start like crap. The (stock) battery tested fine and everything but i got a new one and its been fine ever since. Maybe not enough cold cranking amps? It would turn over fine just wouldnt start.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Jan 22, 2007
  • Jan 22, 2007
I spent a lot of time in San Antonio. I heard alot about the United Stangs stuff. Mike Clark and Angel talked about it sometimes. Most of the stuff we did was with the LSx cars, but we did Ford stuff as well. Last time I saw Murillo and Chip out at San Antonio Raceway they were both a "little" heavier!
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
