Has anyone reversed the way the upper intake faces?
  • Thread starter Thread starter StreetDreamsGT
  • Start date Start date Aug 24, 2006
StreetDreamsGT
449
New Jersey
Aug 24, 2006
  • Aug 24, 2006
I was just wondering how hard it would be to face the upper intake the other way like it is in the non h.o. 302 equipped cars. The only problem i've run into so far has been is that the intake hits my afpr, am I able to change the direction of the fuel rail also?
notch22
22
Katy, TX
Aug 24, 2006
  • Aug 24, 2006
Explaination on why you want to do this por favor?
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Aug 24, 2006
  • Aug 24, 2006
Buy a phenolic spacer... you don't rearrange the house around the furniture
Sicarius428
2,085
Aug 24, 2006
  • Aug 24, 2006
I would use a spacer too. I have an inch spacer for my intake and it barely touched one of the crossmembers on the hood which I cut out. You might be able to get away with a smaller one.
Kevin
vristang
4,933
101
124
Seattle
Aug 24, 2006
  • Aug 24, 2006
Do you have any current pics of the RX-7 conversion?
I think I have seen this on here before, or was that someone else?
The stock fuel regulator may give you more clearance, and you may be ok without the afpr.
I am not sure if you can simply flip the stock fuel rails. Check the angle of the injectors, and where the rails hook into the supply and return lines.
There are other stock Ford vehicles that mounted the regulator in various locations. A trip to the j/y may be a good use of time here?
Are you planning on using egr?
The egr could be tough to rearrange
This sounds like a cool project, please feed us more info
jason
Sicarius428
2,085
Aug 24, 2006
  • Aug 24, 2006
Oh.. didn't look at the sig... Probably don't have much space under the gen 2 hood. An LS1 would fix that problem. hehe
Kevin
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Aug 24, 2006
  • Aug 24, 2006
alot of the older non HO 5 liters like in the old crown vics had the upper facing the other direction. looks funny.
2000xp8
SN Certified Technician
Aug 8, 2003
8,078
1,659
194
NJ
Aug 24, 2006
  • Aug 24, 2006
I could use some pics of this rx7 conversion project, so i can rub it in my buddies face. Told him to drop a 5.0 or ls1 in, instead he's 10,000 bucks into this rotary junk and it still don't run right.
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Aug 24, 2006
  • Aug 24, 2006
I agree with the above spacer suggestion. Just a 5/8" spacer is all you'll need, really, to clear it - lots of guys who've converted to H.O. specs on Panthers (Crown Vics, Town Cars, Grand Monkeys) have flipped the intake around to match the OEM routing and they got by with just a 5/8" spacer. Of course, you could always just buy a set of non-H.O. fuel rails - no real difference in flow rating, just formed to fit the other way around - but that would involve piping the fuel fittings to the other side and whatnot, whereas a spacer is no harder to put on than a plenum gasket.
You might also need to take into consideration that the throttle body linkage will have to be flipped, and a different cable might be needed to make up for the length.
Pics of your completed work are expected, of course.
StreetDreamsGT
449
New Jersey
Aug 29, 2006
#10
  • Aug 29, 2006
  • #10
Kevin
Honestly, for the next one I do I will drop in an LS1 but my mustang was my first love. And i'm still trying to figure out how to get the damn distributor to fit under my turbo II hood let alone my aftermarket typhoon intake! Anyone here happen to know where I could find a shorter distributor?
I promise to upload some pix on here as soon as I get my internet working on my comp at home.
vristang, I had already bought a holley fpr, (i've got a lot of aftermarket parts on the engine n I think it was said that I needed an aftermarket one) soo I want to stick with this one. I don't think I'd need to worry too much about the fuel lines though, because I'm going to be bending custom lines anyway. Yea I was going to be using egr, my big worry was the throttle cable.
2000xp8 - I'm almost at half of what he spent and i've got everything listed in my sig.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Aug 29, 2006
#11
  • Aug 29, 2006
  • #11
that's like "hey guys come lift my car and turn iy 22* while I hold the floormat still cause it's crooked"
Dayzed50
106
Marysville, WA
Aug 30, 2006
#12
  • Aug 30, 2006
  • #12
if i'm not mistaken don't lightnings use gt-40 intakes which are reversed 180*? obviously the fuel rails will be slightly wider with the taller deck but they may be an option, though i can't remember where the fpr was located. also, you may want to check out the throttle cables as they are a factory design for the opposite orientation.
bullitstang1313
713
Indianapolis / Columbus, Indiana
Aug 30, 2006
#13
  • Aug 30, 2006
  • #13
You can pick up some fuel rails out of a thunderbird or lincoln, the fuel pressure regulator is mounted on the other side. As for the throttle cable, you will either have to route it around from the front or you'll have to attach it to the throttle body on the other side of the mounting pin so it will pull it open.
StreetDreamsGT
449
New Jersey
Aug 30, 2006
#14
  • Aug 30, 2006
  • #14
Bullit you're the man! Do you happen to know what year thunderbirds and lincoln i'm looking for? Isn't there also a cable that runs from the automatic trans up the the throttle body?
StreetDreamsGT
449
New Jersey
Sep 1, 2006
#15
  • Sep 1, 2006
  • #15
Anyone happen to know?
StreetDreamsGT
449
New Jersey
Sep 1, 2006
#16
  • Sep 1, 2006
  • #16
Anyone know?
2000xp8
Aug 8, 2003
8,078
1,659
194
NJ
Sep 1, 2006
#17
  • Sep 1, 2006
  • #17
From the looks of ebay cars at least 86-90 lincoln towncars have the 302 with the intake reversed.
Darkwriter77
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Sep 1, 2006
#18
  • Sep 1, 2006
  • #18
86-90 Town Car
86-91 Crown Victoria/Grand Marquis
86-93 Thunderbird/Cougar/Mark VII (lo-po model only, not the LSC or optional H.O. on Bill Blass)
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
  • dan50
  • Jul 18, 2026
dan50
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
