hatch lock
  • Thread starter Thread starter tim_lemmy
  • Start date Start date Apr 25, 2008
T
tim_lemmy
94
  • Apr 25, 2008
last night i was putting some stuff in the back of my car and when I closed the hatch and pulled my keys out the lock tried to come with the keys. I pushed it back in and tried to open the hatch again and i can't get it open, the lock turns but it doesn't click and open. how can i fix this? thanks for the help
Blake
samickguy15
404
Delavan, IL
Apr 25, 2008
  • Apr 25, 2008
Yeah, good luck with that one...You'll have to try and get the hatch popped, probably from the inside...Then disassemble the lock.
squeak93
2,352
418
164
Joplin, Missouri
Apr 25, 2008
  • Apr 25, 2008
Same thing happend to me.. Ur lock broke. U will most likely have to go from the inside and dissamble it. Good luck. I had to do this on a 100 degree summer day.. sucked. Good luck.
T
tim_lemmy
94
  • Apr 25, 2008
how do i pop the hatch from the inside? Is there a safety switch i can pull? or because you can climb over the seat did they leave that off? and once I've disassembled and fixed the problem how do i keep it from happening again?
squeak93
2,352
418
164
Joplin, Missouri
Apr 25, 2008
  • Apr 25, 2008
You basically have to dissasemble the whole entire hatch area with the lid closed. Sucks, hope ur not scared of tight spaces. Only way I found was to take loose the two-four (cant remember been about 3 years now) bolts that hold the latch down to the body of the car. Then u have to get it out of its hole its bolted in. Real fun job but can be done. The go to ur local bone yard and cherry pick until u find a great one. Try not to buy the actuator unless yours isn't working. I just had to puck up the latch itself and saved about 40 bucks on not buying the electronics. Good luck.
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
