Hatchback pop's open with force...
  • Thread starter Thread starter Blue91GT
  • Start date Start date Dec 26, 2007
Blue91GT
33
Atlanta, GA
Dec 26, 2007
  • Dec 26, 2007
I don't know if this is a common problem with the fox hatch, but I am having a bit of trouble. I recetly noticed that the hatch on my 91 GT was a little off, and looked as though it wasn't sealing properly. With further inspection i tugged on the left/driver side of the wing and the hatch popped open. I then went on to replace the upper hatch mechanism that is in the hatch door itself. I installed the new peice and it still pops open!!! This is getting a bit aggravating, I have about a thousand dollar stereo in it and I'd prefer it not get stolen!
Has anyone else had trouble with their hatch? Does anyone know how to fix it?
THANKS!
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Dec 26, 2007
  • Dec 26, 2007
You must have really wanted an answer to this one. You made 3-identical threads.
bloopbloob
578
Alberta
Dec 26, 2007
  • Dec 26, 2007
this is a very common problem. often, adjusting the striker will help solve the problem. just move it and tighten it, then check how it works. if nothing, try a different direction. i also believe there is supposed to be a sleeve over the striker, which mine never had. i just wrapped some electrical tape around it a couple times, and it hasn't popped open since.
90_Red_LX
668
Asheboro, NC
Dec 26, 2007
  • Dec 26, 2007
Is the striker bushing still intact? My door bushing and my hatch striker went out the same day and my hatch wouldn't latch, nor would my door, so I replaced em all.
SuperStang83
1,693
Boyertown, Pa
Dec 26, 2007
  • Dec 26, 2007
I have had this problem and for me it was the striker bushing. You can find them at a junkyard for real cheap, or see if the ones from the doors fit.
Bay_Stang
22
sacramento CA
Dec 26, 2007
  • Dec 26, 2007
the hatch itself might be off as well. if u remove the three screws on the cover plate directly above the back seat u can acess the. remove the strike get the hatch lined back up with the body and then after removing the cover pieces in the trunk close the hatch completely. bolt the striker back in and make inor adjustments until its right farely simple if thats the case, hope this helps
Blue91GT
33
Atlanta, GA
Dec 26, 2007
  • Dec 26, 2007
My bad!!!! The server must have been busy, soo I clicked post multiple times...I guess I get a bit click happy when I have to wait!
RMODEL65
313
brunswick ga
Dec 26, 2007
  • Dec 26, 2007
go to the help section at advance or auto zone abd buy the door striker bushings you need to slice one of them length wise and open it up to spread it over then take another one and spit in half to fit the remaining gap then llength wise about a 2$ FIX
93gtmustang
524
43
49
Dec 26, 2007
  • Dec 26, 2007
Same thing with my hatch. It would pop open if you hit some bumps. The sleeve cracked and broke off and there was nothing left to it. I got a piece of cpvc pipe, 1/2" or 3/4", I can't remember. But I had to bore out the inside some to fit over the metal strike and then sand the outside of the plastic because it was too thick.
Then I adjusted it what seemed like a million times untill I got it right.
It still pops open once in a while. Then I have to adjust it again and it's fine for a while. It's really frustrating!! I was thinking that maybe the latch is worn and or not grabbing tight enough. I may try to get a new latch someday and see if that works.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Dec 27, 2007
#10
  • Dec 27, 2007
  • #10
Move the striker up to latch the hatch. It sounds as if its too low and it isn't grabbing the latch enough.
fiveohlxhatch
27
#11
  • Dec 27, 2007
  • #11
I've never had this problem with my hatch but based on people's posts it sounds like it may be coming soon. Anyone got pics of the striker bushing?
C
clayschmuck
48
San Antonio
Dec 27, 2007
#12
  • Dec 27, 2007
  • #12
If you go to any Autozone, Pep Boys, Western Auto, they have a section where they sell door strikers (along with a bunch of other items such as window cranks). They sell the hatch striker as a complete item and they sell just the individual striker bushing. The bushing looks like a piece of pvc piping. The striker's head is a Torx bit (can't remember the size). The striker is held in place with a blind nut mounted, um, behind where the striker meets the body. Mine broke when I removed it years ago to replace the broken bushing so, I had to go through my magic bag of hardware to find a replacement nut. The difficulty in bolting the new striker in place is finding a wrench to hold the nut in place.....there is also lots of cursing involved with replacing the bushing. You could split one and slide it over the stock striker but eventually that too will fail. Good luck!
Clay
90_Red_LX
668
Asheboro, NC
Dec 27, 2007
#13
  • Dec 27, 2007
  • #13
I bought the hatch striker but it wouldn't work right from the help isle so I took my stock striker and the new striker apart and put the new bushing on the stocker and it works great.
C
clayschmuck
48
San Antonio
Dec 27, 2007
#14
  • Dec 27, 2007
  • #14
Wasn't that great that it was a direct bolt-on and didn't require any modification....wait...there's no such thing!
Good on ya mate!
Blue91GT
33
Atlanta, GA
Jan 8, 2008
#15
  • Jan 8, 2008
  • #15
Thanks for all of your help...I will be fixing it soon! I'll let ya'll know how it goes!
Blue91GT
33
Atlanta, GA
Feb 21, 2008
#16
  • Feb 21, 2008
  • #16
This is an old topic but I finally bought a striker bushing.... It doesn't pop open at all anymore and stays shut when I pull on it! Cost me $6 from mustang restore so I bought 3 just in case!!!
Thankjs for your help!
Need Help, Car Wont Start, I've Gone Through Both Checklists
  • 93silverlx50
  • Jul 22, 2017
  • 2 3
13K
Fox 5.0 Mustang Tech Apr 30, 2019
General karthief
Budget Audio Build (f150 Upgrades Without Keeping Sync)
  • Adieu
  • Oct 28, 2015
  • Mustang Sound & Shine All
2K
Mustang Sound & Shine All Oct 28, 2015
Adieu
  • Blue91GT
  • Dec 26, 2007
Fox 5.0 Mustang Tech Feb 21, 2008
Blue91GT
Cams! (valve event timing, resonance tuning, what's theory, what's fact)
  • FastDriver
  • Oct 27, 2011
6K
Fox 5.0 Mustang Tech Nov 27, 2011
NIKwoaC
Exhaust recirculating into interior
  • Darkwriter77
  • Mar 17, 2009
Fox 5.0 Mustang Tech Mar 18, 2009
f8tlfiveo
