Having some braking problems. Anyone had a similar issue?
  • Thread starter Thread starter stang8urimport
  • Start date Start date Jul 19, 2007
First Prev 2 of 2
Fett
766
#21
  • Jul 20, 2007
  • #21
You might also want to unbolt the master from the booster and look inside the back of the master. I have seen a lot of reman masters have a slight leak internally, causing the same issues.
Nibbie
127
#22
  • Jul 20, 2007
  • #22
If the booster had a leak of anysort will it be dripping brake fluid in the engine bay or under the dash near the firewall? I dont know but thats what happend to me once. Oh if the calipers where bad the brake pads would wear unevenly, I see that somtimes with cars/trucks.
Fett
766
#23
  • Jul 20, 2007
  • #23
If the booster had a leak, he would hear it. The booster doesn't contain fluid.
If a master is leaking bad, you will see the paint on the booster start to bubble and peel away just under where the master is mounted. But that is a normal leaking master. I have seen a lot of reman masters have a very slight leak, that hurts pressure when applying the brakes. You can notice this by unbolting the master from the booster and looking at the booster rod and inside the master. It should be dry of fluid.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 20, 2007
#24
  • Jul 20, 2007
  • #24
If you have a low vacuum condition (less than 17" at idle), the brake booster may not supply all the assist you need with your particular combination of pads and rotors.
Check out the booster and vacuum lines for leaks. Do a basic vacuum test to make sure you have good vacuum (more than 17") at idle speeds.
Pay close attention to the rubber gromment that the brake booster check valve fits in. Also pull the check valve out and try blowing though it. One way it should pass air, the other way it should block all air with no leaks. If it leaks at all replace it.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Jul 20, 2007
#25
  • Jul 20, 2007
  • #25
I agree with a leaking master cylinder would do that.. But I've seen many seals rolled in a master with no visible leaks giving the same problems. Thus I replaced it. I think I will look more into it this weekend. Thanks a lot guys for all your help. I didn't mean to be an ass... I'm just getting frustrated.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jul 20, 2007
#26
  • Jul 20, 2007
  • #26
have you inspected the rear wheel cyl's for any signs of leaks... (or are you 4 wheel disc)
My initial thoughts was booster ( I knew you would check the basics since you are a fellow tech)
did you feel any pedal fade at all
check the vac line to the booster maby you are loosing some vac there causing bad power assist
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Jul 21, 2007
#27
  • Jul 21, 2007
  • #27
Wheel cylinders are good. They're new. Vac line seems to be in good condition. It might possibly be a booster problem.
Mustang5L5
Mod Dude
Feb 18, 2001
43,305
18,010
224
Massachusetts
Jul 21, 2007
#28
  • Jul 21, 2007
  • #28
Might i suggest a 93 cobra booster as a replacement, especially if you are considering any future brake upgrades
BullittAndy
139
#29
  • Jul 21, 2007
  • #29
If its not the booster then you might replace the front pads with another softer set. I had a set of performance pads that after the install had the exact same problem, hard brake pedal but no brakes.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jul 21, 2007
#30
  • Jul 21, 2007
  • #30
can you just go to a parts store and buy a BB for a 93 cobra
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Jul 21, 2007
#31
  • Jul 21, 2007
  • #31
Yep, but it will probably be special order
Mustang5L5
Mod Dude
Feb 18, 2001
43,305
18,010
224
Massachusetts
Jul 21, 2007
#32
  • Jul 21, 2007
  • #32
Yes. but it's special order
http://www.autozone.com/R,APP272231...partType,00143/shopping/partProductDetail.htm
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jul 21, 2007
#33
  • Jul 21, 2007
  • #33
what about a SN95 booster and master will the work fine on a fox without much mod's
Fett
766
#34
  • Jul 21, 2007
  • #34
Yea, but everything I read says that a 93 Cobra BB is a direct swap, and the master only requires modification to the lines and PV because of the missing port.
First Prev 2 of 2
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
Drivetrain Rear noise while braking.
  • 91GTstroked
  • Jul 3, 2024
2K
Fox 5.0 Mustang Tech Jul 10, 2024
91GTstroked
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Brakes Brakes drag when warm. How to diagnose?
  • FastDriver
  • Nov 20, 2023
8K
Fox 5.0 Mustang Tech Apr 2, 2025
