having timing pointer problems
  • Thread starter Thread starter jerry S
  • Start date Start date Jul 14, 2005
jerry S
1,365
52.22N 5.12E
Jul 14, 2005
  • Jul 14, 2005
I bought a Summit Racing harmonic dampner for my 1969 351W, part number SUM-B64269. It is 6.610 inches in diameter compared to 6.2 inches for stock. The really great thing about when you buy this balancer is that neither the Summit web site nor the sales person taking your order will tell you that there is no timing pointer available for this balancer and that you will have to fabricate your own. Is anyone aware of a timing pointer for a 69 351W that will fit a 6.6 inch dampner? I guess anyone who has a fluidampr is in the same spot (6.625 inches)
G
grego37
576
Fresno CA
Jul 14, 2005
  • Jul 14, 2005
does the new balancer have cast in marks , or a sticker with the degrees on it?
jerry S
1,365
52.22N 5.12E
Jul 14, 2005
  • Jul 14, 2005
laser etched marks.
G
grego37
576
Fresno CA
Jul 14, 2005
  • Jul 14, 2005
if you want to use those marks for timing, rotate the engine to exact TDC, and make a pointer and bolt it somewhere near area to where the pointer can reach the marks.
Or
Set the engine to exact TDC and bolt a pointer anywhere you want , and use timing tape to mark your new mark on the balancer.
jerry S
1,365
52.22N 5.12E
Jul 14, 2005
  • Jul 14, 2005
Or
I can do that ok. thanks.
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
D
351w Help
  • dana deamann
  • May 6, 2015
1974 - 1978 Mustang II Talk & Tech May 8, 2015
jozsefsz
If you add a new harmonic damper, do you have to rebalance the crank?
  • jerry S
  • Dec 11, 2005
9K
Classic Mustang Specific Tech Dec 11, 2005
67efivert
Unusual Timing issues - could I have the distributor out 180?
  • Chythar
  • Nov 18, 2007
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Dec 5, 2007
WHITE94COBRA
C4 to AOD swap
  • jlangholzj
  • Mar 22, 2009
32K
Classic Mustang Specific Tech Apr 13, 2009
jlangholzj
