Head Bolt Question.
  • Thread starter Thread starter krazedstang
  • Start date Start date May 4, 2015
krazedstang
670
278
104
Streamwood
May 4, 2015
  • May 4, 2015
I'm starting to get my engine put together, and the ARP head bolts that I had purchased from someone seem to be the 1/2 instead of 7/16. so I was on ARP and can't decide what the difference is between
The Official ARP Web Site | Kits and these The Official ARP Web Site | Kits Except the $100 difference?
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
May 4, 2015
  • May 4, 2015
Brand:ARP
Manufacturer's Part Number:154-3605
Part Type:Cylinder Head Fasteners
Product Line:ARP High Performance Series Cylinder Head Bolt Kits
Summit Racing Part Number:ARP-154-3605
UPC:672036019402
Fastener Style:Bolt
Undercut Stud:No
Head Style:Hex
Fastener Material:Chromoly
Fastener Finish:Black oxide
Washers Included:Yes
Cut to Fit:No
Quantity:Sold as a kit.
Notes:Includes 1/2 in. to 7/16 in. insert washers for cylinder heads with 1/2 in. bolt holes.
Brand:ARP
Manufacturer's Part Number:154-3601
Summit Racing Part Number:ARP-154-3601
UPC:672036003692
Fastener Style:Bolt
Undercut Stud:No
Head Style:Hex
Cut to Fit:No
The only difference I see is the step washers. What heads do you have? this will determine if you will need them or not
krazedstang
670
278
104
Streamwood
May 4, 2015
  • May 4, 2015
@84Ttop I have the Trick Flow 170's
squeak93
2,357
419
164
Joplin, Missouri
May 4, 2015
  • May 4, 2015
1/2 bolts are for a 351 or 302 that has been machined for them. If your 302 is stock you will likely need the 7/16 AND the 1/2 inserts as your heads are machined for 1/2 holes but the block will only take a 7/16
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
May 5, 2015
  • May 5, 2015
You do not need the step washers, The TFS 170's have 7/16 tapered holes out of the box. The top of the whole is 7/16" and the bottom is 1/2", This allows you to use a standard head bolt without trouble. It also makes it easy to open the wholes up later to 1/2" if you ever use them on a 351 or aftermarket block
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
May 5, 2015
  • May 5, 2015
This is incorrect, please see my post above
squeak93
2,357
419
164
Joplin, Missouri
May 5, 2015
  • May 5, 2015
I apologize, I assumed he was looking at step bolts due to his heads were already opened up to 1/2 bolt holes.
84 is correct, if they are out of the box stock, then you just bolt them down with 7/16 bolts.
Reactions: 84Ttop
krazedstang
670
278
104
Streamwood
May 5, 2015
  • May 5, 2015
Awesome, then it'll get the ones without the step washers.
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2025
from6to8
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
