Engine Head Gasket Swap... Questions Within
  • Thread starter Thread starter madspeed
  • Start date Start date Apr 21, 2014
  • 3
  • 4
  • 5
First Prev 2 of 5 Next Last
madspeed
Colonel Mustard
1,332
204
a van down by the river
Apr 22, 2014
#21
  • Apr 22, 2014
  • #21
Or just drink beer
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Apr 22, 2014
#22
  • Apr 22, 2014
  • #22
mikestang63 said:
X2 what Brian said. Use the washers. My guess is because there weren't any, that allowed the head to walk a little on the gasket.
Head dowels wont let that happen.
I've used plenty of heads that step washers could have been used, but didn't do it. And never seen any negative impact from it. That being said, they could help load distribution a little, so its definitely not going to hurt anything by using them.
madspeed
Colonel Mustard
1,332
204
Apr 22, 2014
#23
  • Apr 22, 2014
  • #23
There are dowels present. I will add the step washers for the extra piece of mind
Grabbin' Asphalt
2,029
310
124
Atlanta, Ga
Apr 22, 2014
#24
  • Apr 22, 2014
  • #24
If it happened without them, might as well go another route
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 22, 2014
#25
  • Apr 22, 2014
  • #25
Dowels won't stop a HG from blowing, they are there so when you put the head on, you get proper alignment and the HG don't slip or pinch. Besides the fact he had dowels, he has studs which I think do a good job of keeping the HG aligned. Judging from what mad said about the nuts on the studs, they weren't torqued properly and with the lack of washers led to the blowout on the one cylinder.
madspeed
Colonel Mustard
1,332
204
Apr 22, 2014
#26
  • Apr 22, 2014
  • #26
I hate when the studs nuts arent done properly
Reactions: 84Ttop
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Apr 22, 2014
#27
  • Apr 22, 2014
  • #27
I never said they would. I was just commenting on the fact that you thought the head could walk on the gasket because washers weren't used. Thats not going to happen. The holes in the head gasket like a 9333 are sized to accommodate 1/2" head bolt, so, studs would do a horrible job of keeping things aligned.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 22, 2014
#28
  • Apr 22, 2014
  • #28
K thanks for the clarificaton on what you meant with the dowels. Yes the dowels align the HG and the head, but seeing how the holes are 1/2 in the heads and HG, not using the step washers add to the problem. I've always used them and never had an issue.
madspeed
Colonel Mustard
1,332
204
Apr 22, 2014
#29
  • Apr 22, 2014
  • #29
dumb question, but where exacyly do these washers go upon install, clarification needed as to how many I need please- I asume just one per stud and they replace the flat washers??
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 22, 2014
#30
  • Apr 22, 2014
  • #30
Yep. they go in between the nut on top of the head stud and the head- the step part will fit in the hole in the head. ARP and other companies sell them as a kit. You'll want to put assembly lube on the bottom of the washer, the stud thread and the nut.
Reactions: madspeed
madspeed
Colonel Mustard
1,332
204
Apr 22, 2014
#31
  • Apr 22, 2014
  • #31
do i want blue rtv for the ends of the lower intake or ultra blue?
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 22, 2014
#32
  • Apr 22, 2014
  • #32
Right Stuff
http://www.all-spec.com/products/85224.html?gclid=CJmKt53R9b0CFQIT7AodZEkA6g
Reactions: Noobz347
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Apr 23, 2014
#33
  • Apr 23, 2014
  • #33
^^ This is just plain WRONG...
What Mike said!
mikestang63 said:
Right Stuff
This ^^ again!!!
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Apr 23, 2014
#34
  • Apr 23, 2014
  • #34
Lets here it then. If all your going to say is its wrong, without a reason why you feel differently. Then you might as well not even post.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Apr 23, 2014
#35
  • Apr 23, 2014
  • #35
@liljoe07 I'll send you a PM as I don't want to pollute this thread with our bantering back and forth.
Reactions: Noobz347
madspeed
Colonel Mustard
1,332
204
Apr 23, 2014
#36
  • Apr 23, 2014
  • #36
OP likes bantering
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 23, 2014
#37
  • Apr 23, 2014
  • #37
He like boys too from what I hear?
Reactions: 84Ttop
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 23, 2014
#38
  • Apr 23, 2014
  • #38
I did type that didn't I
Well played Sir.
OP likes bantering
drama queen lol
madspeed
Colonel Mustard
1,332
204
Apr 23, 2014
#39
  • Apr 23, 2014
  • #39
Consensus say yes on using the Right Stuff for lower intake?
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 23, 2014
#40
  • Apr 23, 2014
  • #40
I usually use plain old black RTV, but I'm not opposed to the suggestions above.
  • 3
  • 4
  • 5
Engine Felpro 9333 pt1 (with 8psi boost)
  • JD1964
  • Jan 14, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
Qtrhrse23
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
