Engine Felpro 9333 pt1 (with 8psi boost)
JD1964
there is enough sticking out to grab on to
3,639
1,658
194
Maryland
I finally picked up some AFR Renegade street heads pn 1472 to replace my cast iron GT 40’s. The irons were lifting under boost i think because they’ve been milled too much. The block was decked .003 last time so we are good there. I already have the ARP head stud kit which I will use again.
Im about to order Felpro 9333 PT1 head gaskets for the project. Any objections on the head gasket choice?
Thanks, John
I have acquired the upper and lower intake gaskets too
Lower - Felpro 1250 S3
Upper - Felpro MS 95953
I drained the coolant and removed the upper so far. Then it got cold out so my old bones chickened out. I’ll keep you posted when I get back at it.
Reactions: RaggedGT
1011-2 are good also. Either or, I myself ALWAYS used the 1011-2. Ive had audible detination(lean 10lbs boost) and they held. Just brake clean all surfaces, chase those threads, AND retorque.
On the retorque, the 9333 pt1 are perma-torque. That’s what the pt stands for. What’s everyone’s opinion on that. Are they good to go without a retorque?
D1 stock cam 11psi here, 500+ to. No retorque? How about headers intake? The way I see it, its cheap insurance. Plus gives you a chance to "look at things." Mine started as a daily, so I got into retorquing a long time ago 90s. It never hurt any motor Ive worked on, and Ive seen a bolt or 2 back off. Just my
Reactions: General karthief
You know they quit making pennies, right? I retorque as well especially on the headers. I check them everytime I am messing with the plugs or plug wires just because of some crappy MAC shorties I had the I could never get to seal up. I have run BBK's for years now and they are good to go but I've heard people that have had issues with them as well.
Anyhow, I run the Felpro 1011-02's as well on both cars (AFR 185's on one and Edelbrock Perform RPM's on the other) and retorqued both per my engine builder.
I also run studs on the intakes (upper to heads & lower to upper) and retorque them a couple of times after heat cycles when installing new.
