  • SN95 V6 Mustang Tech
head gasket
  • Thread starter Thread starter epurdy2005
  • Start date Start date May 1, 2004
E
epurdy2005
25
  • May 1, 2004
As i was saying in the other post I think my head gasket it leaking. Because I have to but coolant in my car every 3 weeks or else it starts blowing no heat and then starts overheating..........my car is a 95 3.8 with only 55,000 miles on it.. do you think ford if u twisted there arm do it as part of that recall?
Evan
85GTlover
704
  • May 2, 2004
Wishful thinking, do you notice any coolant in your oil?That is a sign of leaking head gasket, one anyway.
E
epurdy2005
25
  • May 2, 2004
Just did an oil change a couple of weeks ago and it looked just fine.
Evan
J
jmhpa1980
  • May 3, 2004
It's doubtful Ford would do anything. Not on a 10 year old car.
I had a 95 Coupe and the head gaskets went. Cost me $2000 to get it fixed. Good luck with yours!
97v6Silver
it came to $4.56 and i got $0.44 change from a 5,
Apr 22, 2003
843
VA Beach
May 3, 2004
  • May 3, 2004
ahahha change them yourself it's like a 2 hour job
M
mustang95w
317
chicago
May 3, 2004
  • May 3, 2004
I hope your joking. Head gaskets are not hard to change, but there is a lot to do so im sure it wont be done in 2 hours.
9
'96Coupe
15
  • May 4, 2004
Its a long process, as you have to pull the intake, and most of the front cover off the motor just to pull a gasket. The gasket kit sells for around $120 or so from Ford. You might find them elsewhere. 2 hours will not even get you through the tear down phase of the job. Then you must clean the heads themselves, and check them to make sure you don't have to resurface the heads. Then you can start to build back up and that will take longer then the tear down phase, I suspect. Also, you will more then likely be replacing more then just the headgaskets. The intake gaskets, exhaust header gaskets, and valve cover gaskets MUST be replaced as the items are pulled off to get to the heads.
Yes, I'm currently working on a head gasket problem on a 1996 Mustang V-6 that has 166K miles and I'm led to believe the origional factory head gaskets. However, with the gasket blowing and ending up with part of it in the cylinder chamber I've gouged the piston and I'm afraid to see how bad the rod may be bent under that. So, I'll be tearing the motor down to make sure my rods and my crank shaft are okay then bandaging this motor until I can do a V-8 DOHC swap.
Just some information I've found in the last couple of weeks during my mustangs woes.
As for twisting Fords arm? Good luck, its highly doubtful.
M
2001 cobra coolant crossover delete
  • Mike3
  • Jul 5, 2026
  • SVT Tech Forum
SVT Tech Forum Jul 12, 2026
Mike3
M
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
SN95 V6 Mustang Tech Jul 24, 2026
gkomo
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
2001 SVT Cobra Overheating Issue
  • bradencaron0
  • May 8, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 8, 2025
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
