head swap work?
  • Thread starter Thread starter twin_turbo_mk3
  • Start date Start date May 11, 2009
T
twin_turbo_mk3
31
  • May 11, 2009
hi
i had planned to originally stay stock for a little while but a friend recently went afr and his practically giving me his victor heads.
my question is will the head and block surface require machining if "it looks straight"?
or can i just clean it up nice(if it looks straight) and install the head/block with new head gasket?
what headgasket would you guys recoment for mile 302?
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
May 11, 2009
  • May 11, 2009
if you can spot a deck thats level just by looking at it, you should get a medal.
Aluminum heads almost always require a resurfacing, it would be a good idea to have a machine shop go through them and make sure everything is up to par, there are other things to worry about besides the deck, like the springs, valve seals, guides etc.
If your getting the heads cheap, then spend the money now, befor they are on the car and you realize its a problem.
Also, why is he getting rid of the victor jrs for afr's?
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
