Head work
  • Thread starter Thread starter Cobain03
  • Start date Start date Jan 11, 2006
Cobain03
996
Lexington, Ky
Jan 11, 2006
  • Jan 11, 2006
whats normal to be done when sending heads off to be "freshened up" ?
i got prices form the people who may be doing my block: 3 angle valve job is 50 a head, 7 angle compition valve job is 75. milling is 25 a head.
Edbert
3,548
32
109
Austin TX
Jan 11, 2006
  • Jan 11, 2006
"Normal" is a highly subjective term but I think you have already identified much of it. Only other things I'd add to that would be replacing all the valvetrain, springs/valves/retainers. They'll usually hot-tank them and clean them up too. Milling them just insures a good seal on the head gasket unless they plan to take a bunch off in which case you can see a compression ratio increase. The 7 angle is a waste of money for a mild DD in my opinion.
If you want to increase the performance you can have larger valves installed, choose stainless steel valves, have the press-in studs replaced with screw-in ones and have guide plates installed. Also the chamber can be cleaned up and unshrouded a little, then have the ports gasket-matched, the exhaust port could use a little porting too, it is notoriously small on factory 289 heads.
Dark Knight
2,578
Chandler, Az.
Jan 11, 2006
  • Jan 11, 2006
He cant run guide plates, has the early heads with the narrow slot built in..
Odds are that if the heads have never been rebuilt, it will need some new valves and springs for sure.. if you plan on running something other than the stock cam, now is the time to get the matching valve springs
Edbert
3,548
32
109
Austin TX
Jan 11, 2006
  • Jan 11, 2006
I thought only K-code heads had that "slot".
LMan
1,246
Mom's basement
Jan 11, 2006
  • Jan 11, 2006
Not just K-code heads. Other early heads with the non-rail rockers are narrow-slot, later rail-rocker heads have the large hole. The rails maintain alignment in those cases.
milner351
92
The Motor City
Jan 11, 2006
  • Jan 11, 2006
Those are good prices.
Buy new springs that match your cam for sure.
You may need a valve guide or two which will be a few more bucks bot not much.
If you plan on doing any port work, do it before you send the heads in to be machined.
It's a good idea to have the compression face ground just enough to clean it up and make it flat, which usually is not very expensive. Good insurance.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
