  • 1994 - 1995 Specific Tech
header problem
  • Thread starter Thread starter saleener94
  • Start date Start date Apr 8, 2007
saleener94
153
Compton,CA
Apr 8, 2007
  • Apr 8, 2007
I just through in my new BBK shorty headers. I got a leak on the passenger side right above the rear spark plug. I could feel the air with my hand. I took it off and checked it and I see nothing wrong. What would be the best thing to do now?
R
red95gtconvert
382
Ponca city, OK
Apr 8, 2007
  • Apr 8, 2007
Pull the header off and put some RTV ultra copper silicone around the exhaust ports on the header gasket, let it tack up for 15 minutes then reinstall the header and hope for the best. I've used this method with great results.
saleener94
153
Compton,CA
Apr 8, 2007
  • Apr 8, 2007
thanx. i'll try that. Its just hard doing it alone.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 8, 2007
  • Apr 8, 2007
Go buy a set of stage 8 header bolts aswell. I was constantly fixing header leaks because the bolts loosened off. Now with these bolts and there locks I haven't had to do one in years.
saleener94
153
Compton,CA
Apr 8, 2007
  • Apr 8, 2007
I have the stage 8 locking bolts and fel-pro gaskets. I haven't put the little locking clips because I wanted to check it for leaks first.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 8, 2007
  • Apr 8, 2007
Well glad to hear you have the right bolts.
saleener94
153
Compton,CA
Apr 8, 2007
  • Apr 8, 2007
I looked at alot of reviews before I bought these and I thought it was going to be smooth and easy, but I guess not. Is it safe to drive to a mechanic?
parchisi
519
New Mexico
Apr 8, 2007
  • Apr 8, 2007
Hell, my car hasn't NOT had a header leak since I started driving it.
bso
46
  • Apr 9, 2007
Did you check to see if the leak is not at the EGR tube?
saleener94
153
Compton,CA
Apr 11, 2007
#10
  • Apr 11, 2007
  • #10
thanx for everything guyz. problem solved.The leak was between the header and h-pipe. A muffler shop quickly solved the problem by banging the flange up with a long screwdriver and a hammer and putting washers on the studs. Its actually driveable now but the leak is really, really minor and he said that it will seal with the heat as I drive more. Sounds more aggressive now.
gcomfx.com
3,690
Republic, MO
Apr 12, 2007
#11
  • Apr 12, 2007
  • #11
Another good to hear post. Very happy to see people posting the follow up SOLUTION.
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
