header wrap
  • Thread starter Thread starter mrmcmillen
  • Start date Start date Jan 18, 2006
mrmcmillen
43
Carrollton, Texas
Jan 18, 2006
  • Jan 18, 2006
what is the best way to go about installing and securing header wrap?
LMan
1,246
Mom's basement
Jan 18, 2006
  • Jan 18, 2006
Be advised that header wrap seriously promotes corrosion.....and almost all header manufacturers will NOT honor their warranty if wrap is used on their product.
Edbert
3,548
32
109
Austin TX
Jan 18, 2006
  • Jan 18, 2006
If you are planning on wrapping them to reduce engine compartment temps then look into coating them with ceramics. It might not work as well but it WILL be cheaper in the long run since you wont have to replace the headers often.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Jan 18, 2006
  • Jan 18, 2006
Header wrap only promotes corrosion if it gets wet all the time. I wrapped a header for a '91 Civic and the header didnt have ANY rust after two years. It also stays alot drier here in CA.
The header was out of the car and I cut strips longer than I thought I needed. Then I secured them with hose clamps. I only wrapped the header because the A/C lines came really close to it. I wouldn't do it for fun.
ozstang65
313
Queensland, Australia
Jan 21, 2006
  • Jan 21, 2006
I have had wrapped headers crack, it doesn't let enough heat escape (funnily enough!). Ceramic coat is the best way to go.
wild70stang
317
  • Jan 21, 2006
I almost bought header wrap for my headers when I asked pertronix and a couple other places about whether or not it voided their warrenty. well guess what..........IT DID. Jet hot ceramic coatings is probably the best place to get ur headers ceramic coated. Even though their price is high, they strip down any paint, and coat the headers on the inside and outside. they also do some stuff in between but I forgot
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
D
Exhaust Difficulty of fixing exhaust leak at manifold
  • dqureshi06
  • Aug 27, 2026
Fox 5.0 Mustang Tech Aug 28, 2026
General karthief
D
AOD TV cable replacement bushing - loose pin?
  • DuluthFoxbody
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Monday at 8:30 AM
DuluthFoxbody
D
N
Mods
  • newmex999
  • Oct 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 6, 2026
