  • 2005 - 2009 Specific Tech
Headers for cheap....
  • Thread starter Thread starter BlueBossS197
  • Start date Start date Sep 25, 2006
BlueBossS197
53
Oklahoma
Sep 25, 2006
  • Sep 25, 2006
I'm sure many people have been wanting to know where to get longtubes for cheap, but I'll ask again. Anyone know?
Oh, and besides eBay.
Blazing Saddles
34
  • Sep 26, 2006
Flowtech ceramic coated $245 @ Summit.
baylor2010
73
  • Sep 26, 2006
Do you want longtubes or shorties?
BlueBossS197
53
Oklahoma
Sep 26, 2006
  • Sep 26, 2006
longtubes
5.0 Coupe
64
9
Tucson, AZ
Oct 1, 2006
  • Oct 1, 2006
I picked up some JBA LT's from RPM. Ceramic Coated, $800.00 cheapest I found for JBA LT. The only problem with RPM is no money back on any item, but you can exchange. I didnt have any problems, got the headers and cats, took a day to install. Sounds great!!
M
mikes06gt
47
  • Oct 1, 2006
what are the benefits of the longtubes over the shorties?
does one make more horsepower or torque or is it sound preference?
P
pspc271
339
Dover, DE
Oct 1, 2006
  • Oct 1, 2006
Did the long tubes require that you jack the motor up for the install?
5.0 Coupe
64
9
Tucson, AZ
Oct 1, 2006
  • Oct 1, 2006
The LT's (according to several sources) produce better HP then the shortys. (shortys anywhere from 5 to 10 hp, LT 15 to 25hp) The nice thing about the S197 is it looks like it was made for the LT's, plenty of space to install them (once you remove the starter and Motor mount plates). The header Clearance is like stock, you don't see them unless you are underneath the car and the sound, well it has a very deep old school muscle car rumble to them. As for price, the LT's are not cheap. You will need to replace the Cats with one made for the headers or use a straight x pipe made for the headers. The total cost can be around 1k, but I really like them. I currently use the JBA LT's with Cats and stock mufflers and I diffently feel the difference in power.
5.0 Coupe
64
9
Tucson, AZ
Oct 1, 2006
  • Oct 1, 2006
yes, you do one side at a time. I actually removed the motor mount plates for easier installation (its only 4 - 15mm bolts on each side). I used a small piece of 2x4, standing it straight up on the jack end, and jacked the front of the engine up. I was able to do the installation pretty easily using large Jack stands which raised the car up about 2 feet. You will also need to move the steering shaft out of the way, unbolt the bottom bolt holding the shaft to the rack, unbolt the 2 bolts holding the rack in place and push it forward. You might mark the steering shaft so you return it to the right postion when putting it back. The whole job took about 5 hours. The hardest part of putting in the headers is holding the gasket in place while installing them.
Rock36
76
Modesto, CA/Germany
Oct 1, 2006
#10
  • Oct 1, 2006
  • #10
I see you are from Cali also, actually not all that far from Modesto. Anyway I know Longtubes won't pass smog in CA, but I don't understand why. If you are still running catalytic converters shouldn't that still allow the car to pass the sniffer test? What are you planning on doing when you have to get the car checked in a few years?
W
top loader transmissions
  • WilliamJCC.
  • Jun 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 6, 2026
70mstang
N
Thermostat housing
  • nataliaisafraid
  • Dec 8, 2025
2005 - 2009 Specific Tech Apr 2, 2026
Cmrd
C
Rear quarter window regulator
  • BADAZZOMBIE08
  • Mar 29, 2026
2005 - 2009 Specific Tech Mar 29, 2026
BADAZZOMBIE08
Best Ebay aftermarket Radio/screen
  • Shurkeel
  • Oct 8, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 9, 2026
gkomo
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
