94Fauxbra said:im running NGK's. Im new to the whole "Aluminum Head Craze"....is there a certain plug you should run with aluminum heads???
94Fauxbra said:Vibe...is there any reasoning behind running the Autolites or is it just the thing to do?
I believe Motorcraft & Autolite are actually the same plug.1fstgt said:man i've had nothing but trouble with autolites. i always just use motorcraft plugs because i can get them pretty cheap.
yourself.
but you could be right. i'm just saying that we have lots of trouble with aftermarket plugs and especially the autolites. well champions are the worst but that's a whole 'nother story.That sounds like a good idea, except that the Iridium plugs are like $14 *each*. I can put in a set of Autolite 24's or 3924's for about $14 *total*.17yrOldStanger said:if you are gonna change your plugs, minds well go for iridium core ones. denso or ngk work nicely. im running NGK and they are great.
I have you set up pretty much and I use autolite plugs gapped at .032 because of the blower do not gap them at the factory settings of .054.94GTLaserRC said:Joe: Im gonna go ahead and get new plugs for when we put the Romac In, since they didnt change them with the blower. Which ones should I get for My application? If they are ones we have at Walmart, Ill get them there. If not, Ill have to get them where you say is the best place.
I figured I may as well do them while I got the car there doing the Romac. Once that balancer is done, and I get the right plugs/gap in there, Ill get the 4:1 FMU and the Tune, and hopefully I should be all set (for now, anyway)
RC
Sup95Cobra said:I have you set up pretty much and I use autolite plugs gapped at .032 because of the blower do not gap them at the factory settings of .054.
