headers
  • Thread starter Thread starter Cobain03
  • Start date Start date Nov 12, 2004
Cobain03
996
Lexington, Ky
Nov 12, 2004
  • Nov 12, 2004
hey guys whats the deal with tri y headers has anyone heard of
pertronix thats were mine come from i got mine installed and the pitman harm hits the headers i know i posted it before but i hate to take these off and use the old one but it don't sterr to the left much at all too much to dent the headers i was told to use 66 moter mounts that would help does anyone know about that ?? some one give me some input please !!!
stephen4785
321
Fort Worth Texas
Nov 13, 2004
  • Nov 13, 2004
Iv heard quite a few people have the same problems with Tri Y's. Some of them just loose'end the motor mounts and shifted the engine a little and thats all they needed. As for the different motor mounts . Got me? Im assuming the 67's sit the motor a little higher or something.
blue66tang
1,092
Medford, OR
Nov 14, 2004
  • Nov 14, 2004
The 66s had taller motor mounts. I think it sits about an 1/2 higher or something like that. Do you have power sterring, if so you can buy a drop bracket.
Cobain03
996
Lexington, Ky
Nov 14, 2004
  • Nov 14, 2004
i did the drop bracket,, that no the problem the problem is the pitman arm hits the header pipe when going to the left
jb1dsl
566
Marianna, Fl.
Nov 14, 2004
  • Nov 14, 2004
Yeah you should switch to the 66 mounts, they are taller and give you the right amount of clearance.
Cobain03
996
Lexington, Ky
Nov 14, 2004
  • Nov 14, 2004
are you saying this form experiance or from what seems right?
jb1dsl
566
Marianna, Fl.
Nov 14, 2004
  • Nov 14, 2004
i have a 66 but my buddy has a 64 1/2 and when he put his jba headers on they nade contact with stuff. he changed to later model mounts and it gave him more clearance
Cobain03
996
Lexington, Ky
Nov 15, 2004
  • Nov 15, 2004
i guess im gonna have to try em. how much higher did the engine sit? is jacking up the tranny required as well so it balances out?
blue66tang
1,092
Medford, OR
Nov 15, 2004
  • Nov 15, 2004
No,
Glen's 1965 5.0
477
Tomball,Texas
Nov 15, 2004
#10
  • Nov 15, 2004
  • #10
Depending on how much hieght you need but I put a large body shim between the motor mount and the frame mount and it solved my problem.
Cobain03
996
Lexington, Ky
Nov 16, 2004
#11
  • Nov 16, 2004
  • #11
i did shims at first to rasie the motor to help clear the headers from the fender well and other things but still didn't help the pitman arm ,, i think i should have used shortys insted i guess
blascrw
191
Opelika, AL
Nov 16, 2004
#12
  • Nov 16, 2004
  • #12
question
Have you called pertronix?
I had good tech support and when I thought they sent me the wrong gaskets they shipped them ot right away...
Give them a call.
Ron
Cobain03
996
Lexington, Ky
Nov 16, 2004
#13
  • Nov 16, 2004
  • #13
well i call them and spoke to a rep. and basicely he said there was some mods that come with every set of headers( that is bull ) if i know that i wouldn't have doen them i thought they bolt up really so i don't know maybe time to put the old ones back on i guess take a lose can't drive this way ( away to the left lol )
thanks guys for al the help i knew you all would know alot about this as always thanks again
blue66tang
1,092
Medford, OR
Nov 16, 2004
#14
  • Nov 16, 2004
  • #14
Hooker super comps is the way to go. In my opinion at least. I never had a single problem with them, they fit perfect and look good.
Cobain03
996
Lexington, Ky
Nov 16, 2004
#15
  • Nov 16, 2004
  • #15
how did they clear the pitman arm??
blascrw
191
Opelika, AL
Nov 16, 2004
#16
  • Nov 16, 2004
  • #16
unique
You may have some unique problem...
Tri-y's have been around as long as mustangs have and you don't hear of too many problems...
Mine fit perfectly...so have others...and the same goes for any other brand...
so I wish I could be more help...you may find the same problem with a different brand as you have now...
Ron
Cobain03
996
Lexington, Ky
Nov 16, 2004
#17
  • Nov 16, 2004
  • #17
well i think its time for e-bay and back to the orig i guess
blue66tang
1,092
Medford, OR
Nov 16, 2004
#18
  • Nov 16, 2004
  • #18
I have absolutely no clearence issues. Well i take that back i am using a lakewood scatter sheild for a late model mustang, so i had to put a small ding in one of the pipes. Not enough to cause any real flow loss. But when i had the old bellhousing in it fit perfect.
Cobain03
996
Lexington, Ky
Nov 17, 2004
#19
  • Nov 17, 2004
  • #19
but my problem is pitman arm i don't think a small dent will help i will more this weekeend
302 coupe
1,952
Macon, Ga.
Nov 17, 2004
#20
  • Nov 17, 2004
  • #20
I'm pretty sure the headers are not your problem. Like others have said, they've been making tri-y's for mustangs for 40 years, they were designed to fit the mustang chassis specifically. I have tri-y's and have zero problems whatsoever. In fact, I used the tri-y's because I knew they would fit right. It kinda sounds like your pitman arm has been improperly installed to the steering box, like maybe it was installed off-center. If its a few teeth off, the travel of the pitman arm will interfere with other components. Take this into consideration when/if you try another set of headers because they too may also not fit properly.
P
rear Impact absorbers.
  • Praetorious
  • May 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2026
Praetorious
P
Hello fellow Mustang fanatics.
  • 580HP*428Cj
  • Apr 2, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
josep4
Electrical Need help identifying what these electrical items are (93 LX 5.0)
  • dan50
  • Apr 11, 2026
Fox 5.0 Mustang Tech Apr 12, 2026
dan50
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
G
1982 Mustang GL 5.0 single to dual exhaust conversion
  • Guyton
  • Jun 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 1, 2025
limp
