Exhaust Headers
  • Thread starter Thread starter 510notch
  • Start date Start date Jan 31, 2015
510notch
26
Bay area California
Jan 31, 2015
  • Jan 31, 2015
Hey whats up guys? so i have a question that i hope one of you can answer and or help me out with,
today i replaced my headers and lets just say never again will i try to do that again lol.
so everything finally went into place but now my car sounds real bad like theres a clicking noise coming from the engine this noise was never there prior to this, i accidentally broke a spark plug and replaced it with a random one i found in my garage, my question is did i not tighten them good or is the spark plug to blame for the weird noise?
Thanks in advance for any feedback.
Mustang5L5
Mod Dude
Feb 18, 2001
43,360
18,106
224
Massachusetts
Feb 1, 2015
  • Feb 1, 2015
It's either a leak from the headers gasket (they sonetimrs need to be retightened) or the random spark plug doesn't fit.
You should get the right spark plug.
Reactions: A5literMan and 510notch
madspeed
Colonel Mustard
1,332
204
a van down by the river
Feb 1, 2015
  • Feb 1, 2015
likely leaking at the gaskets. Did you use new header gaskets?
Reactions: 510notch
510notch
26
Bay area California
Feb 1, 2015
  • Feb 1, 2015
Thanks guys, yeah i used the gaskets that came with the bbk headers and from reading on here it looks like im going to go buy some new ones along with new spark plugs.
i think they didnt seal right because i installed the two screws down at the connector pipe first, the reason i did this is because if i do the manifold screws first its impossible to align the
studs into the exhaust pipe any tips for this?
madspeed
Colonel Mustard
1,332
204
Feb 1, 2015
  • Feb 1, 2015
you've gotta tighten the header bolts before the studs to the h pipe or you risk not getting the gaskets to seal, as you've found out already
510notch
26
Bay area California
Feb 1, 2015
  • Feb 1, 2015
Yeah man its my first time working on a car so i just winged it and failed lol, i will remove the bolts on the h pipe and push it back so i have room to play and install the bottom bolts last.
madspeed
Colonel Mustard
1,332
204
Feb 1, 2015
  • Feb 1, 2015
we've all been there, live and learn. It'll work out!
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Feb 1, 2015
  • Feb 1, 2015
OK, you have a header gasket leak. Undue the headers at the collectors, then remove the header bolts at the head. Make sure the exhaust port area on the heads is clean. Carefully use a razor blade and some brakecleen to clean them. Get a good set of Felpro or Percy's exhaust gaskets and ARP bolts. If the heads are aluminum put anti sieze on the bolt threads. Install the headers with the gaskets installed and snug them all up. Torque them down to about 12-15 ft lb from the inside out. Then go and reinstall the mid pipe to teh collectors evenly, going back and forth on each side to tighten them up or you will cock the pipe and have a leak. When all is tightened up, go back and check all the header bolts again for torque. Start and run the car and after it warms up turn it off and let it cool, then retorque all the bolts again as they can back off. You may need to retighten the header and collector bolts a few times. That is why I use stainless steel allen head header bolts with lock washers- tighten them up once and they never back out.
Reactions: 510notch and A5literMan
FoxMustangLvr
I love my Pimp
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Feb 2, 2015
  • Feb 2, 2015
Do you have a BBK mid-pipe to go with those BBK headers? Typically a brand name header fits up best with it's same brand H/X pipe. Mixing and matching could possibly lead to collectors being misaligned and cause a headache.
510notch
26
Bay area California
Feb 2, 2015
#10
  • Feb 2, 2015
  • #10
Naw i will be using my stock one since i am currently saving for a transmission rebuild. i thought of buying a new one but just rather do the tranny first.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
