headlight and brigtning
snake109
60
Austin TX
what products would you recomend to brighten the headlights and paint, i was planning on using rubing compound for the paint but if you know somthing better and not too pricy let me know. as for the headlights all the stuff i tried only worked for a few months then they get yellow again.
Anything you do with the headlights isn't going to be a permanent solution. Before I replaced my lights, I wet sanded the lenses with 800 then 1000 grit, then went over that with 3M rubbing compund, and finished up with a good coat of wax. That lasted the longest of any method I've tried.
stykthyn said:
just replace the lamps and be done with it.
I made mine last 10 years by sanding/polishing, but what people don't seem to realize is that the inside gets worn too. The reflector inside is an important part of how bright your lights are. If I had known how much better I could see with new ones, I would have replaced them sooner. IMO, OEM is the best for the headlight.
My 91 lenses are almost opaque.
I found I can get a set of clear Cobra style headlights at NAPA. I was told $75.00 for the pair but I havent been over there yet to check on them. I already bought clear corners and clear marker lights from a local speed shop.
mgwshel said:
For the whole 6 piece set? That $105 is for the *set.*
You can waste your time getting them 80% clear with polishing compound, and various grits of sandpaper, or you can drop a little over a hundred dollars and have OEM Ford headlamps that can be properly aimed and won't fog up.
Cjponyparts.com
HEADLIGHT KIT 1987-1993
Part #: HLK1
Price: 119.95
If you want to tackle the headlight restoration, use this guide...
Here is a perfect DIY how to
http://www.nseconsulting.com/bmw/hpt.pdf
