  • SN95 4.6L Mustang Tech
headlight panel removal
  • Thread starter Thread starter sonic281
  • Start date Start date Nov 1, 2011
sonic281
79
glendale az
Nov 1, 2011
  • Nov 1, 2011
is the headlight panel hard to remove or is it riveted in like on fox bodies. this is for an 04 gt. sorry if i posted this in the wrong spot
DJ Fury
72
Nov 2, 2011
  • Nov 2, 2011
The headlight assembly is extremely easy to remove. Pop the hood and look down at the back of the assembly and you'll see 2 slide pins that secure it in place. Pull the pins up and out and you can then pull out on the headlight housing.
When you get it far enough out you'll have access to the bulb connections of which there are 2.
sonic281
79
glendale az
Nov 2, 2011
  • Nov 2, 2011
Thanks for the info much appreciated, but i mean the whole header panel that holds the bumper up mine is broke so my bumper is hanging down.
J
jrp1588
78
Evansville, IN
Nov 2, 2011
  • Nov 2, 2011
Tagging along. My header panel is broken at the tab where it mounts to the bumper. I just discovered it was replaceable yesterday.
sonic281
79
glendale az
Nov 2, 2011
  • Nov 2, 2011
i ordered a new one from american muscle. gonna put it in friday just hopin i dont run into anything to difficult
sonic281
79
glendale az
Nov 4, 2011
  • Nov 4, 2011
k i just did mine its the easiest thing ever bumper is simple to take off and the header panel is just 4 little bolts did it in like 45 min
J
jrp1588
78
Evansville, IN
Nov 4, 2011
  • Nov 4, 2011
Good to know. Before I found out it was replaceable I was thinking of jerry-riggng something.
sonic281
79
glendale az
Nov 4, 2011
  • Nov 4, 2011
might as well just replace it ya know. im gonna have to take my bumper back off i found that the actual metal bumper is bent down from previous owner pissed me off. gonna tie it to a tree and bend it back. thinkin about puttin a saleen bumper on it when i take it back off what you think?
Flghtmstr1
572
Springfield, PA
Nov 6, 2011
  • Nov 6, 2011
When I bought my car back in 2005, the header panel was cracked on both sides. I replaced it in about an hour. It's an easy job.
txredgt
1,343
33
69
Nov 6, 2011
#10
  • Nov 6, 2011
  • #10
What are the tale-tale signs that it needs to be replaced? I have a hunch that mine needs it but I can't just pull the bumper off and look right now.
Flghtmstr1
572
Springfield, PA
Nov 7, 2011
#11
  • Nov 7, 2011
  • #11
For me, it was obvious as I could see the cracks in the header panel. Generally speaking, though, if the headlamps are loose and/or move around when installed in the vehicle, the header panel is probably cracked and needs to be replaced.
sonic281
79
glendale az
Nov 7, 2011
#12
  • Nov 7, 2011
  • #12
for me i could see it cracked in half behind the grille and the bumper was hanging about an 1 1/2 inch under the headlights very simple job to fix
txredgt
1,343
33
69
Nov 7, 2011
#13
  • Nov 7, 2011
  • #13
And the new panel I assume fixed the headlight and bumper issues? This might be the next thing I need to look into.. 10 yr old cars are at that age where it needs upkeep a little bit. Thanks fellas for the responses and for me thread jacking
sonic281
79
glendale az
Nov 8, 2011
#14
  • Nov 8, 2011
  • #14
yeah fixed it pretty good
R
Door Panels
  • RGP413
  • Aug 29, 2026
AeroCoupe
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
gkomo
Fox Brake lines hitting bump stops
  • keel
  • Sep 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
keel
M
Electrical lights
  • Magnet86
  • Sep 11, 2026
Fox 5.0 Mustang Tech Sep 14, 2026
Magnet86
M
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
