Headlight switch issues (seen smoke)
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
I was driving my car today and I had the light's on and I turned them off because it wasn't dark out and I seen smoke come from the switch area is this a common problem with the GT light switch or mustang light switch in general. Also the dash part right above the switch was kinda warm after I seen that.
Anyone ever heard of a problem like this or had this happen to them.
Been there done that. It is because the switch itself has all the current going through it to your lights versus a relay or something simple like that to keep it up under the hood. I would guess you were running fog lights also?? There are lots of cheap fixes ranging from installing a relay set-up under the hood to a new beefed up switch box to replace the fried one. Both could probably be found using the search function on here. I did the relay route and it was pretty easy, plus you don't have to mess with it again.
A very common problem on the GTs.
First you're going to have to find out where the smoke came from. It is possible that the switch survived, but the wiring did not. Once you've assessed/repaired the damage you should modify the circuit to prevent future occurences. A popular fix can be found at foglight fix
well, it depends on the mount of damage already done. I definitely wouldn't test your main headlight's function at night. They may leave you stranded :). The fog light fix link is what I did. I would run the headlights only (and test them for function/safety during the daytime) until you get it fixed. With that foglight fix it will set you up so you can run fogs only. Something you can't do stock.
Definately do the wiring upgrade that Saleen noted. :nice:
Do Canada cars have DRL's? If so, I might consider putting relays on lows and highs too. I chose to do this to save the switchgear (now running well under 1 amp through the headlight, fog and MF switch instead of 15 amps, give or take).
And dont forget to check the existing wire from the headlight switch to the MF switch (on my '88 it was red/yellow IIRC). That's one of them that likes to burn, and you wouldnt necessarily check it at the MF switch's end.
Good luck.
That happend to me 2 summers ago, which is when i did the corrals fog light switch. Now my fog lights run independant from my headlights.
This is what prolly burned up in yours - its the foglight harness that plugs into the switch. Heres what mine looked like after its smoke show.
