headlight wiring question?
  • Thread starter Thread starter mclemore102
  • Start date Start date Apr 10, 2005
M
mclemore102
47
  • Apr 10, 2005
I have a 93 mustang and the low beam lights won't work.The high beams and the signal lights all work.On the back of the front lights there are four plugs one for the headlight,one for the turn signal and one for the marker light.There is one plug left it has to metal prongs inside it where does it go?
HISSIN50
34
129
Apr 10, 2005
  • Apr 10, 2005
could be for fogs, depending upon where the plug is. all cars came with fog light wiring, whether or not they had fogs from the factory. fogs would be a two wire connector.
good luck.
M
mclemore102
47
  • Apr 10, 2005
It is a lx coupe and the plug is wiried into the same wires as the headlights.I was just wondering if i didn't have something plug up.I have also checked the headlight switch and the multi function switch the look good no melted or burnt wires.What could be the problem you think?
HISSIN50
34
129
Apr 10, 2005
  • Apr 10, 2005
i would doublecheck the MF switch. it splits up whether highs or lows should be sent to the headlights. if you have the low beam wire back out, it cant get the juice to the lights (been there, done that. it was subtle - i really had to look for the connector - it was backed out just a little bit).
good luck.
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
68 headlights hot working
  • Butchd88
  • Aug 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 3, 2026
Butchd88
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
J
Electrical problem with headlights
  • jeremykrell308
  • Oct 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 3, 2025
General karthief
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
