headlight wiring
does anyone know what the highest power level rating on a set of HID headlights can be run on stock wiring?? im looking at getting a set of PIAA HID bulbs but im not sure what the highest rating i can go on stock wiring, and if its not enough were i could get a decent wiring harness for better ones
It seems to me that the Kelvin ratings are for the quality or tint of the light, not the actual lumins or heat output.
Simply stated, I would not run more than the stock current though the headlight wires.
Good luck.
The headlights use 16 gauge wire, which should be good for about 10 amps. Seeing that there are 2 bulbs, that works out to be about 5 amps per side.
More than 10 amps total current would require the use of a relay. The foglight fix popular for the GT foglights uses a relay. See http://www.corral.net/tech/maintenance/foglights.html for more information.
An HID bulb runs at 35 watts at 3 amps. Which is less than a 55 watt halogen bulb. However, when the lights are turned on, the bulb has to be warmed up. This happens during the first 5 seconds when you flip the headlight switch. During this time, the ignitors are pulling around 15 amps, which is more than the stock wiring can handle. If you're going to do things right, you'll either have to make or buy a wiring harness that uses relays to keep the stock wiring from frying.
www.suvlights.com sells wiring harnesses at decent prices.
