  • 1994 - 1995 Specific Tech
Headlights turn on and off ramdomly!!!
  • Thread starter Thread starter juiced_94gt
  • Start date Start date Oct 12, 2008
juiced_94gt
1,143
Southern California
Oct 12, 2008
  • Oct 12, 2008
Well ever since i fired up my car for the second time it's been nothing but weird issues, first my driver turn signal works properly only when it wants to, it makes a clunking sound from the bottom of the car when it's cold, and now the other day I was driving on the freeway and the headlights were turning on and off at random but the lights on the dash were fine...what would cause this?? grounds seem to be ok.
juiced_94gt
1,143
Southern California
Oct 12, 2008
  • Oct 12, 2008
Oh and the passenger power door lock wont work anymore either
HISSIN50
34
129
Oct 12, 2008
  • Oct 12, 2008
Your headlight switch might be bad or the light switch connector is starting to melt. It only takes a minute to inspect each, and they're relatively cheap, so that's where I'd start.
juiced_94gt
1,143
Southern California
Oct 12, 2008
  • Oct 12, 2008
How do you check??
mhespenh
50
Charlotteville/Blacksburg, Virginia
Oct 12, 2008
  • Oct 12, 2008
juiced_94gt said:
How do you check??
Remove the dash panel that houses the gauges (to do this you have to remove the light switch knob first, which is a pain the first time you try it) then remove the two bolts holding the light switch in. On the back of the switch you'll see the connector, if its melting you'll easily be able to tell. If it isn't I'd bust out the voltmeter/multimeter and check all the wires for correct values.
Good luck, I freaking HATE tracking down wiring problems.
juiced_94gt
1,143
Southern California
Oct 13, 2008
  • Oct 13, 2008
what are the correct values for the wires I should be checking?
HISSIN50
34
129
Oct 13, 2008
  • Oct 13, 2008
Red/yellow is the headlight switch output to the MF switch.
A bad connection at the MF switch is also possible.
Anyhow, here's a schematic
O
Resolved 2004 Mustang GT 4.6. No crank, no dash lights, No headlights or dome, No radio, no Hazards.
  • oldtimeracer
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2026
oldtimeracer
O
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
AeroCoupe
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
2000xp8
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
