Headliner sound/heat barrier
  • Thread starter Thread starter Red5oh
  • Start date Start date Nov 15, 2007
1 of 2 Next Last
R
Red5oh
377
DFW, Texas
Nov 15, 2007
  • Nov 15, 2007
I asked this on the bottom of another headliner question, so I apologize for the double post... but...
I have dynamat extreme installed on the roof metal on a 67 coupe. I was messing around and starting fitting the headliner and it went in pretty quick, BUT, I have not installed anyything else besides the dynamat!
Should I have put in some type of thermal material (jute, 1/4 foam???) or anything to help with the heat? I dont think the dynamat will help much in that department... but just checking.
Thanks for the help.
Tim65GT
1,149
West Texas
Nov 15, 2007
  • Nov 15, 2007
I put this in mine and it works:
(and I live in El Paso, TX)
http://www.mustangsunlimited.com/itemdy00.asp?T1=M248+01
R
Red5oh
377
DFW, Texas
Nov 15, 2007
  • Nov 15, 2007
Yeah, that looks like the jute style backing underneath the carpet, right? Probably a little more dense.
I was wondering if I needed it 'also' since I put the dynamat...
I used to live in El Paso, so I know what you are saying!
Mark
bnickel
5,640
lubbock, texas
Nov 15, 2007
  • Nov 15, 2007
i have the same stuff in mine. it's just a factory replacement headliner insulation kit, not sure that it's really a jute but i guess it's similar.
E
entdoc
89
greenville, SC
Nov 15, 2007
  • Nov 15, 2007
I would definitly put a neoprene or jute type material in addition to the Dynamat. You will get far better heat and sound insulation with both
T
truck90278
382
Redondo Beach, CA
Nov 15, 2007
  • Nov 15, 2007
Talk to the folks at "Quiet Ride" they use a combination of dynamat (for sound0 and "Acousta Shield for sound deadening. Their system has been in pretty much all the magazines and gets good reviews. We will be using there system in our 65. It's not the cheapest, but works welll
bnickel
5,640
lubbock, texas
Nov 15, 2007
  • Nov 15, 2007
i definitely agree. also the headliner won't look right without the factory stuff under it, that's what gives it that kind of puffy look in the corners and stuff. this is just my opinion of course so take it for what it's worth.
J
JEE740
18
  • Nov 15, 2007
Do you have a link for this product?
Chris
E
entdoc
89
greenville, SC
Nov 15, 2007
  • Nov 15, 2007
these guys aer very good to work with and the site explains a lot about noise control
http://www.secondskinaudio.com/?gclid=CIawr92G4I8CFR4-Igodigc02A
R
Red5oh
377
DFW, Texas
Nov 15, 2007
#10
  • Nov 15, 2007
  • #10
Mine didnt have one in it when I bought it... but the only places it would apply are near the edges where that edge trim goes. Other than that, it gets no where near anything metal.
T
truck90278
382
Redondo Beach, CA
Nov 15, 2007
#11
  • Nov 15, 2007
  • #11
Chris
quietride.com-- they are in Stockton, Ca. You want to glue some Jute padding onto the rear pillars to fill them out as per bnickel
valley82
204
San Diega, Ca.
Nov 15, 2007
#12
  • Nov 15, 2007
  • #12
I bought a kit from "mustangsplus" or "mustangsunlimited" can't remember which,
it came with dynamat and a thick "1/4 - 3/8 inch" material covered with a foillike substance.
I used this combo under the carpet, headliner and behind the rear seat huge difference in outside noise and heat.
R
Red5oh
377
DFW, Texas
Nov 16, 2007
#13
  • Nov 16, 2007
  • #13
That is kinda what the dynamat is... but its about 1/8" thick with a sticky tar substance that goes against the metal then an aluminum face to it that you are exposed to.
It appears I will be adding some type of 'padding' to the dynamat that is there... I am just having a hard time discerning what to use? If all else fails, I will use that 1/4" headliner material to help fill in those spaces on the rear pillars that everyone is talking about.
T
truck90278
382
Redondo Beach, CA
Nov 16, 2007
#14
  • Nov 16, 2007
  • #14
Mustang Plus sells the Quiet Ride sound deadening, that appears to be what you received
M
mikethebike
358
Greenville, SC
Nov 16, 2007
#15
  • Nov 16, 2007
  • #15
Have you seen the 1/4" bubble-pack with aluminum covering on both sides? It has an 'r' value of 11, weighs nothing and won't rot over time like some fiber products do. Check with the local street-rod shops to find some. I installed it in the floor of my 65 and it lowered the temp from unbearable in the summer to down right comfortable.
valley82
204
San Diega, Ca.
Nov 16, 2007
#16
  • Nov 16, 2007
  • #16
Yes, quietride is it. The kit came with dynamat to put in strategic places and the carpet padding type stuff goes over that.
valley82
204
San Diega, Ca.
Nov 16, 2007
#17
  • Nov 16, 2007
  • #17
opps missfire.
R
Red5oh
377
DFW, Texas
Nov 17, 2007
#18
  • Nov 17, 2007
  • #18
Since I have the dynamat in place already (full coverage).... what do you think is best? The 1/4 foam headliner stuff, or the carpet type padding?
What about the rear pillars? What goes over them? padding (to round out the edges)?
C
chromedog
554
worlds center for speed
Nov 17, 2007
#19
  • Nov 17, 2007
  • #19
the bubble wrap/ tin foil is also available at lowes, under the name reflectix... i did the headliner, inside the doors and quarters, and firewall of my 65, and i think it does a great job, besides not weighing more than a few ounces.
R
Red5oh
377
DFW, Texas
Nov 19, 2007
#20
  • Nov 19, 2007
  • #20
Ok... last question folks... what adhesive to use? In the past I used the 3M spray on, but that can be a mess. Most sites say to use the 3M 08001 (yellow) that comes in a tube, which sounds much cleaner.
Any other suggestions... I am going to start gluing this thing in TODAY!!!! (Yeah)
1 of 2 Next Last
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
M
  • mnky99
  • Sep 5, 2025
mnky99
M
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
TMI T-top headliner installation trouble getting retaining strip on
  • stxdriver98544
  • Aug 27, 2020
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2020
Mstng93SSP
R
1965 mustang body work, Complete Floor Pan Assembly install questions
  • runawayabc123
  • Jun 1, 2022
7K
Classic Mustang Specific Tech Sep 14, 2025
GOvert
G
