Hear fuel pump no fuel pressure?
STROKED_LX
43
My stang wouldnt start so I checked the fuel pressure and not getting any, when I turn the key hear my fuel pump prime (sounds loud). I checked my fuel filter it was ok but I went a head and replaced still same problem. Could my fuel pump be leaking internaly? What should I check next?
Update:
well i removed my fuel filter and tried priming it up and no fuel came out, so i ended up replacing the pump just now. I checked fuel pressure after replacing pump its between 30psi -35psi, (stock pump) 89 notch, that normal?
car now starts up just fine :)
I guess the old pump was making noise but wasnt pumping fuel. noticed some metal flakes on the strainer. Here it is.
