Heater Problems
miksax
48
Hey Guys-
I have a '91 5 liter hatchback.
I remember this from last winter, and I never acted on it because the weather got warm and I didn't use the heat any more. Now that it's cooling off again, I have noticed this problem:
When I turn on the heat to floor, I get a musty smell and there is a "fog-like" stuff that comes out of the defroster vents up by the windshield. I never turned it to the vent setting, because I was afraid of what might come out! I was just messing around with it again today and I noticed that when the selector is set to floor there is still air coming out the defroster vents by the windshield.
I have had the car for quite a few years of cold weather and I never had this issue before. Is there something that I can clean to get rid of the musty fog stuff? Replace something?
Thanks for any advice!
Mike
It sounds to be like you have a small leak in your heater core. Does your car smell like anti-freeze when you see this mist?
As far as air coming out of the defrost when you ahve it set to the floor... I believe that's normal (at least for my 86 it is). I always have a small amount of air coming out of the defroster when the selector is set to the floor.
Before you do anything... Take coat hanger, cut the end off, and straighten it.
On the passenger side of your firewall, there's a little rubber nozzle that points toward the proximity of your header collector. Fish the hanger up in there and root around a bit to make sure that it's clear.
This is the drain for your HVAC box. If you see water come out after you do this, then your problem is likely solved.
WARNING!!!!
Be careful when you put the hanger up in there. Don't force it. You can poke a hole in your heater core if you get it way up in there and apply too much force.
