HEI question from the new guy
  • Thread starter Thread starter thenewguy65
  • Start date Start date Jun 16, 2006
T
thenewguy65
53
  • Jun 16, 2006
This car has an HEI distributor, how can I tell if it's vacuum advanced or mechanical. If it's mechanical I'd have to switch it to run the Autolite 4100 since it has vacuum secondaries correct ?
thehueypilot
1,084
Medina,Tennessee
Jun 16, 2006
  • Jun 16, 2006
Look for the silver can sticking out the side if the dist w/a vacuum hose running to it which is the vacuum advance. If its not there you have just a mech advance only dist. but it has nothing to do with vac secondaries.
67bluestang
193
Tucson, Arizona
Jun 16, 2006
  • Jun 16, 2006
Vacuum advance on the distributor should have nothing to do with the vacuum secondaries on your carb, not that i'm aware of anyway. Its been a long time since i messed with the autolite but i think the secondaries should be a function of the carb itself. The HEI vacuum advance uses ported vacuum from your carb to advance ignition timing.
T
thenewguy65
53
  • Jun 16, 2006
If that's true then it doesn't matter what HEI distributor I have correct ? I appreciate the patience helping a new guy out. I am learning as I go. I am enjoying the satisfaction of learning and doing this myself. I would have been screwed 10 years ago, thank God for the internet.
66moneypit
536
Northern Va
Jun 16, 2006
  • Jun 16, 2006
I found a good article that helped explain it.
http://www.ask.com/webcp?q=how+do+v...m/techarticles/135_0402_carb/&page=3&o=0&ws=1
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
R
1974 Datsun 620 pickup / 5.0L HO
  • RJH46
  • Aug 24, 2025
  • Other Auto Tech
Other Auto Tech Aug 24, 2025
347 with Vortech V2 and Holley quick fuel, AFR Renegades a tremec tko 600 advice for newbie pls
  • Schargedfox
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2026
Schargedfox
